Shell
Functions
The Shell node is used to execute a shell script.
With EL expression #{Job.getNodeOutput()}, you can obtain the desired content (4000 characters at most and counted backwards) in the output of the shell script run by the Shell node.
Example:
To obtain <name>jack<name1> from a shell script (script name: shell_job1) output, enter the following EL expression:
#{StringUtil.substringBetween(Job.getNodeOutput("shell_job1"),"<name>","<name1>")} Shell jobs in DataArts Factory determines whether a script is successfully executed based on the returned value. If the return value is 0, the script is successfully executed. If the value is not 0, the script fails to be executed.
Parameters
Table 1 and Table 2 describe the parameters of the Shell node.
| Parameter | Mandatory | Description |
| Shell or Script | Yes | You can select Shell statement or Shell script.
| Host Connection | Yes | Selects the host where a shell script is to be executed. NOTICE:
| Script Parameter | No | Parameter transferred to the script when the shell script is executed. Parameters are separated by spaces. For example: a b c. The parameter must be referenced by the shell script. Otherwise, the parameter is invalid. NOTE: Do not enter sensitive information, such as the AK, SK, password, and authorization information. |
| Interactive Input | No | Interactive information (for example, passwords) provided during shell script execution. Interactive parameters are separated by spaces. The shell script reads parameter values in sequence according to the interaction situation. The following is an example of using the read -p syntax: read -p "Parameter 1 and parameter 2"Variable 1 Variable 2 NOTE: Do not enter sensitive information, such as the AK, SK, password, and authorization information. |
| Node Name | Yes | Name of the node. It contains a maximum of 128 characters, including letters, digits, hyphens (-), underscores (_), slashes (/), angle brackets (<>), and periods (.). By default, the node name is the same as that of the selected script. If you want the node name to be different from the script name, disable this function by referring to Disabling Auto Node Name Change. |
| Node Status Polling Interval (s) | Yes | How often the system checks whether the node execution is complete. The value ranges from 1 to 60 seconds. |
| Max. Node Execution Duration | Yes | Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will be executed again. |
| Retry upon Failure | Yes | Whether to re-execute a node if it fails to be executed. Possible values:
| Retry Condition | No | If Retry upon Failure is set to Yes, retry conditions can be set. Enable Retry Condition and set the return code range. The shell job can determine whether to retry a failed node based on the return code. You can define the return codes that can be used to determine whether to retry a failed node. |
| Policy for Handling Subsequent Nodes If the Current Node Fails | Yes | Operation that will be performed if the node fails to be executed. Possible values:
| Enable Dry Run | No | If you select Dry run, the node will not be executed, and a success message will be returned. |
| Task Groups | No | Select a task group. If you select a task group, you can control the maximum number of concurrent nodes in the task group in a fine-grained manner in scenarios where a job contains multiple nodes, a data patching task is ongoing, or a job is rerunning. |
