CSS
Functions
The CSS node is used to process CSS requests and enable online distributed searching.
Parameters
Table 1 and Table 2 describe the parameters of the CSS node.
| Parameter | Mandatory | Description |
| Node Name | Yes | Name of a node. The name must contain 1 to 128 characters, including only letters, numbers, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). |
| Cluster or Data Connection | Yes | Select Cluster or Connection. If you want to enable the security mode for CSS clusters, select Connection. |
| CloudSearch Cluster | Yes | This parameter is required when you select Cluster for Cluster or Data Connection. Connection to CloudSearch. A CloudSearch cluster has been created in CloudService. Currently, only clusters of version 5.5.1 is supported. |
| CDM Cluster Name | Yes | This parameter is required when you select Cluster for Cluster or Data Connection. Name of the selected CDM cluster. The CDM cluster functions as a proxy to forward requests. If there are no CDM clusters available in the drop-down list, create one on the CDM console. |
| Data Connection | Yes | This parameter is required when you select Connection for Cluster or Data Connection. Select a data connection. |
| Request Type | Yes | Possible values:
| Request Parameter | No | Parameter of the request. For example, to query the dlfdata mapping type in the dlf_search index, set this parameter to: /dlf_search/dlfdata/_search |
| Request Body | No | The request body is in JSON format. This parameter is mandatory when Request Type is POST, PUT, or HEAD. |
| CloudSearch Output Path | No | Path where output data is to be stored. |
| Node Status Polling Interval (s) | Yes | How often the system check completeness of the node. The value ranges from 1 to 60 seconds. |
| Max. Node Execution Duration | Yes | Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will be executed again. |
| Retry upon Failure | Yes | Whether to re-execute a node if it fails to be executed. Possible values:
| Policy for Handling Subsequent Nodes If the Current Node Fails | Yes | Operation that will be performed if the node fails to be executed. Possible values:
| Enable Dry Run | No | If you select this option, the node will not be executed, and a success message will be returned. |
| Task Groups | No | Select a task group. If you select a task group, you can control the maximum number of concurrent nodes in the task group in a fine-grained manner in scenarios where a job contains multiple nodes, a data patching task is ongoing, or a job is rerunning. |
