Updated on 2026-08-13 GMT+08:00
MRS Spark
Functions
The MRS Spark node is used to execute a predefined Spark job on MRS.
Spark is an open-source parallel data processing framework. It helps you easily and quickly develop big data applications and perform offline processing, stream processing, and interactive analysis on data.
Parameters
Table 1, Table 2, and Table 3 describe the parameters of the MRS Sparknode node.
Table 1 Parameters of MRS Spark nodes
Mandatory
Node Name
Yes
Name of a node. The name must contain 1 to 128 characters, including only letters, numbers, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>).
By default, the node name is the same as that of the selected script. If you want the node name to be different from the script name, disable this function by referring to Disabling Auto Node Name Change.
MRS Cluster Name
Yes
Name of the MRS cluster.
To create an MRS cluster, use either of the following methods:
  • Click . On the Clusters page, create an MRS cluster.
  • Go to the MRS console to create an MRS cluster.
MRS Resource Queue
No
Select a created MRS resource queue.
Select a queue you configured in the queue permissions of DataArts Security. If you set multiple resource queues for this node, the resource queue you select here has the highest priority.
Spark Job Name
Yes
MRS job name. It can contain a maximum of 64 characters. Only letters, digits, hyphens (-), and underscores (_) are allowed.
The system can automatically enter a job name in Job name_Node name format.
The job name cannot contain Chinese characters or more than 64 characters. If the job name does not meet requirements, the MRS job will fail to be submitted.
Process Type
Yes
Processing type of the Spark job
  • Batch: The node waits for the Spark job execution to complete.
  • Stream: The node is executed as long as the job is successfully started. Each time the job is scheduled in the future, the system checks whether the job is in running state. If the job is in running state, it is successfully executed.
Note that this parameter only specifies the processing mode. You must set parameters for the selected mode.
The stream mode is available for restricted use. To use it, contact customer service or technical support.
JAR Package
Yes
Select a JAR package. Before selecting a JAR package, upload the JAR package to the OBS bucket, create a resource on the Manage Resource page, and add the JAR package to the resource management list. For details, see Creating a Resource.
If you configured an MRS tenant plane connection and selected keytab for MRS Authentication Type in Management Center, you cannot select an OBS JAR package as the MRS Spark JAR package. DataArts Studio and MRS are not connected to the same OBS. MRS cannot identify the OBS domain name transferred by DataArts Studio. As a result, an error message is displayed, indicating that the domain name cannot be accessed.
JAR File Parameters
No
Parameters of the JAR package.
Do not enter sensitive information, such as the AK, SK, password, and authorization information.
Program Parameter
No
Used to configure optimization parameters such as threads, memory, and vCPUs for the job to optimize resource usage and improve job execution performance. This parameter is specified by a parameter in your program. MRS is responsible for passing the parameter only.
This parameter is mandatory if the cluster version is MRS 1.8.7 or later than MRS 2.0.1.
For details about the program parameters of MRS Spark jobs, see Running a Spark Job in the MapReduce Service User Guide.
Input Data Path
No
Path where the input data resides.
Output Data Path
No
Path where the output data resides.
Table 2 Advanced parameters
Mandatory
Node Status Polling Interval (s)
Yes
How often the system check completeness of the node. The value ranges from 1 to 60 seconds.
Max. Node Execution Duration
Yes
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will be executed again.
Retry upon Failure
Yes
Whether to re-execute a node if it fails to be executed. Possible values:
  • Yes: The node will be re-executed, and the following parameters must be configured:
    • Retry upon Timeout
    • Maximum Retries
    • Retry Interval (seconds)
  • No: The node will not be re-executed. This is the default setting.
    If retry is configured for a job node and the timeout duration is configured, the system allows you to retry a node when the node execution times out.
    If a node is not re-executed when it fails upon timeout, you can go to the Default Configuration page to modify this policy.
    Retry upon Timeout is displayed only when Retry upon Failure is set to Yes.
Policy for Handling Subsequent Nodes If the Current Node Fails
Yes
Operation that will be performed if the node fails to be executed. Possible values:
  • Suspend execution plans of the subsequent nodes: stops running subsequent nodes. The job instance status is Failed.
  • End the current job execution plan: stops running the current job. The job instance status is Failed.
  • Go to the next node: ignores the execution failure of the current node. The job instance status is Failure ignored.
  • Suspend the current job execution plan: If the current job instance is in abnormal state, the subsequent nodes of this node and the subsequent job instances that depend on the current job are in waiting state.
Enable Dry Run
No
If you select this option, the node will not be executed, and a success message will be returned.
Task Groups
No
Select a task group. If you select a task group, you can control the maximum number of concurrent nodes in the task group in a fine-grained manner in scenarios where a job contains multiple nodes, a data patching task is ongoing, or a job is rerunning.
Table 3 Lineage
Input
Add
Click Add. In the Type drop-down list, select the type to be created. The value can be DWS, OBS, CSS, HIVE, DLI, or CUSTOM.
OK
Click OK to save the parameter settings.
Cancel
Click Cancel to cancel the parameter settings.
Modify
Click to modify the parameter settings. After the modification, save the settings.
Delete
Click to delete the parameter settings.
View Details
Click to view details about the table created based on the input lineage.
Output
Add
OK
Cancel
Modify
Delete
View Details
Click to view details about the table created based on the output lineage.
