DWS SQL
Functions
The DWS SQL node is used to transfer SQL statements to DWS. Data Warehouse Service (DWS) is an online data processing database that runs on the public cloud architecture and platform.
For details about how to use the DWS SQL operator, see Developing a DWS SQL Script and Job.
Context
This node enables you to execute DWS statements during batch or real-time job processing. You can use parameter variables to perform incremental import and process partitions for your data warehouses.
Parameters
Table 1, Table 2, and Table 3 describe the parameters of the DWS SQLnode node.
| Parameter | Mandatory | Description |
| SQL or Script | Yes | You can select SQL statement or SQL script.
| Data Connection | Yes | Data connection that is configured in the SQL script. The value can be changed. |
| Database | Yes | Database that is configured in the SQL script. The value can be changed. |
| Script Parameter | No | If the associated SQL script uses a parameter, the parameter name is displayed. Set the parameter value in the text box next to the parameter name. The parameter value can be an EL expression. If the parameters of the associated SQL script are changed, click |
| Dirty Data Table | No | Name of the dirty data table defined in the SQL script. The dirty data attributes cannot be edited. They are automatically recommended by the SQL script content. Syntax for the DWS dirty data table: with table_name or log into table_name |
| Matching Rule | N/A | Enter a Java regular expression used to match the DWS SQL result. For example, if the expression is (?<=\()(-*\d+?)(?=,) and the SQL result is (1,"error message"), then the matched result is "1". |
| Failure Matching Value | N/A | If the matched content equals the set value, the node fails to be executed. |
| Node Name | Yes | Name of the SQL script. The value can be changed. The rules are as follows: Name of a node. The name must contain 1 to 128 characters, including only letters, numbers, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). By default, the node name is the same as that of the selected script. If you want the node name to be different from the script name, disable this function by referring to Disabling Auto Node Name Change. |
| Node Status Polling Interval (s) | Yes | How often the system check completeness of the node. The value ranges from 1 to 60 seconds. |
| Max. Node Execution Duration | Yes | Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will be executed again. |
| Retry upon Failure | Yes | Whether to re-execute a node if it fails to be executed. Possible values:
| Policy for Handling Subsequent Nodes If the Current Node Fails | Yes | Operation that will be performed if the node fails to be executed. Possible values:
| Enable Dry Run | No | If you select this option, the node will not be executed, and a success message will be returned. |
| Task Groups | No | Select a task group. If you select a task group, you can control the maximum number of concurrent nodes in the task group in a fine-grained manner in scenarios where a job contains multiple nodes, a data patching task is ongoing, or a job is rerunning. |
| Parameter | Description |
| Input | |
| Add | Click Add. In the Type drop-down list, select the type to be created. The value can be DWS, OBS, CSS, HIVE, DLI, or CUSTOM. |
| OK | Click OK to save the parameter settings. |
| Cancel | Click Cancel to cancel the parameter settings. |
| Modify | Click |
| Delete | Click |
| View Details | Click |
| Output | |
| Modify | Click |
| Delete | Click |
