Updated on 2026-01-28 GMT+08:00
Rest Client
Functions
The Rest Client node is used to respond to RESTful requests in Huawei Cloud. This node executes different service requests, including GET, POST, PUT, and DELETE.
For details about how to use the Rest Client operator, see Obtaining the Return Value of a Rest Client Node.
If some APIs of the Rest Client node cannot be called due to network restrictions, you can use a shell script to call the APIs. You need to have an ECS and ensure that the ECS can communicate with the API to be called. Then, create a host connection in DataArts Studio and use the CURL command to call the API using the shell script.
Rest Client operators do not support response bodies larger than 30 MB.
Parameters
Table 1, Table 2, and Table 3 describe the parameters of the Rest Client node.
Table 1 Parameters of Rest Client nodes
Mandatory
Node Name
Yes
Name of a node. The name must contain 1 to 128 characters, including only letters, numbers, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>).
Agent Name
Yes
Name of a CDM cluster. The CDM cluster provides the agent connection function.
If the selected CDM cluster is in the same VPC as the third-party service, the REST client can call APIs on the tenant plane.
You can select multiple clusters and must ensure that at least one cluster can be connected. If multiple clusters can be connected, DataArts Factory randomly connects one.
URL Address
Yes
IP address or domain name and port number of the request host. For example: https://192.160.10.10:8080
The URL can contain up to 256 characters.
HTTP Method
Yes
Type of the request. Possible values:
  • GET
  • POST
  • PUT
  • DELETE
API Authentication Mode
Yes
  • IAM: APIs can be accessed only by cloud users. The request header of a message sent by DataArts Studio to an API contains the authentication information of the current user.
  • Non-authentication: Authentication is not required for calling APIs.
Request Header
No
Click to add a request header. The parameters are described as follows:
  • Parameter Name
    Name of a parameter. The options are Content-Type and Accept-Language.
  • Parameter Value
    Value of the parameter
URL Parameter
No
Enter a URL parameter. The value is a character string in key=value format. Character strings are separated by newlines. This parameter is available only when HTTP Method is set to GET. Set these parameters as follows:
  • Parameter
    The parameter contains a maximum of 32 characters, including only letters, numbers, hyphens (-), and underscores (_).
  • Value
    The value contains a maximum of 64 characters, including only letters, digits, hyphens (-), underscores (_), number signs (#), open braces ({), and close braces (}).
Request Body
Yes
The request body is in JSON format. This parameter is available only when HTTP Method is set to POST or PUT.
Check Return Value
Yes
Checks whether the value of the returned message is the same as the expected value. This parameter is available only when HTTP Method is set to GET. Possible values:
  • YES: Check whether the return value is the same as the expected one.
  • NO: No need to check whether the return value is the same as the expected one. A 200 response code is returned (indicating that the node is successfully performed).
Property Path
Yes
Path of the property in the JSON response message. Each Rest Client node can have only one property path. This parameter is available only when Check Returned Value is set to YES.
For example, the returned result is as follows:
  "param1": "aaaa",
  "inner":
      "inner":
          "param4": 2014247437
       "param3": "cccc"
     "status": 200,
     "param2": "bbbb"
The param4 path is inner.inner.param4.
You can also learn how to configure this parameter by referring to Obtaining the Return Value of a Rest Client Operator.
Request Success Flag
Yes
Enter the request success flag. If the returned value of the response matches one of request success flags, the node is successfully performed. This parameter is available only when Check Returned Value is set to YES.
The request success flag can contain only letters, numbers, hyphens (-), underscores (_), dollar signs ($), open braces ({), and close braces (}). Separate values with semicolons (;).
Request Failure Flag
No
Enter the request failure flag. If the returned value of the response matches one of request failure flags, the node is successfully performed. This parameter is available only when Check Returned Value is set to YES.
The request failure flag can contain only letters, numbers, hyphens (-), underscores (_), dollar signs ($), open braces ({), and close braces (}). Separate values with semicolons (;).
Retry Interval (seconds)
Yes
If the return value of the response message does not match the request success flag, the node keeps querying the matching status at a specified interval until the return value of the response message is the same as the request success flag. By default, the timeout interval of the node is one hour. If the return value of the response message does not match the request success flag within this period, the node status changes to Failed. This parameter is available only when Check Returned Value is set to YES.
The response message body parses the transfer parameter.
No
Specify the mapping between the job variable and JSON property path. Separate parameters by newline characters.
For example: var4=inner.inner.param4
var4 is a job variable. The job variable must contain 1 to 64 characters, including only letters and numbers. inner.inner.param4 is the JSON property path.
This parameter takes effect only when it is referenced by the subsequent node. When this parameter is referenced, the format is ${var4}
The variable name (for example, var4) must be unique in the current job.
Table 2 Advanced parameters
Mandatory
Max. Node Execution Duration
Yes
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will be executed again.
Retry upon Failure
Yes
Whether to re-execute a node if it fails to be executed. Possible values:
  • Yes: The node will be re-executed, and the following parameters must be configured:
    • Retry upon Timeout
    • Maximum Retries
    • Retry Interval (seconds)
  • No: The node will not be re-executed. This is the default setting.
    If retry is configured for a job node and the timeout duration is configured, the system allows you to retry a node when the node execution times out.
    If a node is not re-executed when it fails upon timeout, you can go to the Default Configuration page to modify this policy.
    Retry upon Timeout is displayed only when Retry upon Failure is set to Yes.
Policy for Handling Subsequent Nodes If the Current Node Fails
Yes
Operation that will be performed if the node fails to be executed. Possible values:
  • Suspend execution plans of the subsequent nodes: stops running subsequent nodes. The job instance status is Failed.
  • End the current job execution plan: stops running the current job. The job instance status is Failed.
  • Go to the next node: ignores the execution failure of the current node. The job instance status is Failure ignored.
  • Suspend the current job execution plan: If the current job instance is in abnormal state, the subsequent nodes of this node and the subsequent job instances that depend on the current job are in waiting state.
Enable Dry Run
No
If you select this option, the node will not be executed, and a success message will be returned.
Task Groups
No
Select a task group. If you select a task group, you can control the maximum number of concurrent nodes in the task group in a fine-grained manner in scenarios where a job contains multiple nodes, a data patching task is ongoing, or a job is rerunning.
Table 3 Lineage
Input
Add
Click Add. In the Type drop-down list, select the type to be created. The value can be DWS, OBS, CSS, HIVE, DLI, or CUSTOM.
OK
Click OK to save the parameter settings.
Cancel
Click Cancel to cancel the parameter settings.
Modify
Click to modify the parameter settings. After the modification, save the settings.
Delete
Click to delete the parameter settings.
View Details
Click to view details about the table created based on the input lineage.
Output
Add
OK
Cancel
Modify
Delete
View Details
Click to view details about the table created based on the output lineage.
