DIS Stream
Functions
The DIS Stream node is used to query the status of a DIS stream. If the DIS stream is normal, you can perform other nodes. If the DIS stream is abnormal, the DIS Stream node will send an error message and exit. If you want to perform other nodes, you must set Failure policy to Proceed to the next node. For details about how to set Failure policy, see Table 2. The node is used to monitor a DIS stream.
Parameters
Table 1 and Table 2 describe the parameters of the DIS Stream node.
Parameter |
Mandatory |
Description |
Node Name |
Yes |
Name of a node. The name must contain 1 to 128 characters, including only letters, numbers, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). By default, the node name is the same as that of the selected stream. If you want the node name to be different from the stream name, disable this function by referring to Disabling Auto Node Name Change. |
Stream Name |
Yes |
Select or enter the DIS stream to query. When entering the stream name, you can reference job parameters and use the EL expression. For details, see Expression Overview.
To create a DIS stream, you can use either of the following methods:
Parameter |
Mandatory |
Description |
Max. Node Execution Duration |
Yes |
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will be executed again. |
Retry upon Failure |
Yes |
Whether to re-execute a node if it fails to be executed. Possible values:
Policy for Handling Subsequent Nodes If the Current Node Fails |
Yes |
Operation that will be performed if the node fails to be executed. Possible values:
Enable Dry Run |
No |
If you select this option, the node will not be executed, and a success message will be returned. |
Task Groups |
No |
Select a task group. If you select a task group, you can control the maximum number of concurrent nodes in the task group in a fine-grained manner in scenarios where a job contains multiple nodes, a data patching task is ongoing, or a job is rerunning. |
