CDM Job
Functions
The CDM Job node is used to run a predefined CDM job for data migration. This node works with Cloud Data Migration (CDM) to schedule CDM jobs in DataArts Factory. This node is used to execute a job in a specified CDM cluster.
If you have configured a macro variable of date and time in a CDM job and schedule the CDM job through DataArts Factory, the system replaces the macro variable of date and time with (Planned start time of the data development job – Offset) rather than (Actual start time of the CDM job – Offset).
Parameters
Table 1, Table 2, and Table 3 describe the parameters of the CDM Job node. Configure the lineage to identify the data flow direction, which can be viewed in the DataArts Catalog module.
| Parameter | Mandatory | Description |
| CDM Cluster Name | Yes | Name of the CDM cluster to which the CDM job to be executed belongs. You can select two CDM clusters to improve job reliability.
| Job Type | Yes |
| CDM Job Name | No | This parameter is required only when Job Type is set to Existing jobs. Name of the CDM job to be executed. If the CDM job uses the job parameters or environment variables configured during data development, data can be indirectly migrated based on the parameters or variables during node scheduling in the DataArts Factory module. |
| CDM Job Message Body | No | This parameter is required only when Job Type is set to New jobs. Enter the JSON message body of the CDM job. For convenience, you can choose in the Operation column of an existing CDM job, copy the JSON content, and modify the content here. If the CDM job uses the job parameters or environment variables configured during data development, data can be indirectly migrated based on the parameters or variables during node scheduling in the DataArts Factory module. |
| Node Name | Yes | Name of a node. The name must contain 1 to 128 characters, including only letters, numbers, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). By default, the node name is the same as that of the selected CDM job. If you want the node name to be different from the CDM job name, disable this function by referring to Disabling Auto Node Name Change. |
| Node Status Polling Interval (s) | Yes | Specifies how often the system check completeness of the node task. The value ranges from 1 to 60 seconds. |
| Max. Node Execution Duration | Yes | indicates the execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will be executed again. |
| Retry upon Failure | Yes | Whether to re-execute a node if it fails to be executed.
| Policy for Handling Subsequent Nodes If the Current Node Fails | Yes | Operation that will be performed if the node fails to be executed. Possible values:
| Enable Dry Run | No | If you select this option, the node will not be executed, and a success message will be returned. |
| Task Groups | No | Select a task group. If you select a task group, you can control the maximum number of concurrent nodes in the task group in a fine-grained manner in scenarios where a job contains multiple nodes, a data patching task is ongoing, or a job is rerunning. |
| Parameter | Description |
| Input | |
| Add | Click Add. In the Type drop-down list, select the type to be created. The value can be DWS, OBS, CSS, HIVE, DLI, or CUSTOM. |
| OK | Click OK to save the parameter settings. |
| Cancel | Click Cancel to cancel the parameter settings. |
| Modify | Click |
| Delete | Click |
| View Details | Click |
| Output | |
| Modify | Click |
| Delete | Click |
