Node Overview
A node defines the operations performed on data. DataArts Factory provides nodes used for data integration, database operations, resource management, and computing and analysis. You can choose your desired nodes.
- Node parameters can be presented using Expression Language (EL). For details about how to use EL, see Expression Overview.
- Nodes cannot be connected in serial or parallel mode.
Serial connection: Nodes are run one by one. Specifically, node B runs only after node A is finished running.
Parallel connection: Nodes are run at the same time.
Figure 1 Connection diagram
