Moving a Job or Job Directory
You can move a job file from one directory to another or move a job directory to another directory.
A job has been developed. For details about how to develop a job, see Developing a Pipeline Job.
- Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
- On the DataArts Studio console, locate a workspace and click DataArts Factory.
- In the left navigation pane of DataArts Factory, choose .
- Move a job or job directory.
- In the job directory, right-click a job or job folder and select Move.
Figure 1 Selecting a job to be moved
- In the displayed dialog box, configure the target directory.
Figure 2 Moving a job
Figure 3 Move a directory
Table 1 Parameters for moving a job or job directory Parameter
Select Directory
Directory to which the job or job directory is to be moved. The parent directory is the root directory by default.
- Click OK.
Method 2: drag-and-drop
Select a job or job folder and drag and drop it to the target folder.
Method 3: batch selection and move
Select multiple jobs and move them to the target folder.
