Updated on 2025-09-09 GMT+08:00
Copying the Job Name and Renaming a Job
You can copy the name of a job and rename a job.
A job has been developed. For details about how to develop a job, see Developing a Pipeline Job.
  1. Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
  2. On the DataArts Studio console, locate a workspace and click DataArts Factory.
  3. In the left navigation pane of DataArts Factory, choose Development > Develop Job.
  1. Locate the target job in the job directory, right-click the job name, and select Copy Name to copy the job name to the clipboard.
    Figure 1 Copying the job name
Renaming a job
  4. In the job directory, select the job to be renamed. Right-click the job name and choose Rename from the shortcut menu.
    Figure 2 Renaming a job
  5. In the displayed Modify Job Name dialog box, change the job name.
    Figure 3 Renaming a job
    Table 1 Job renaming parameters
    Job Name
    Name of the job. Must consist of 1 to 128 characters and contain only letters, digits, hyphens (-), underscores (_), and periods (.).
  6. Click OK.
