Copying a Script
This section describes how to copy a script.
A script has been developed based on Developing Scripts.
- Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
- On the DataArts Studio console, locate a workspace and click DataArts Factory.
- In the left navigation pane of DataArts Factory, choose .
- In the script directory, select the script to be copied, right-click the script name, and choose Copy Save As. Figure 1 Copying a script
- In the displayed dialog box, configure related parameters. Table 1 describes the parameters.
Table 1 Script directory parameters Parameter
Script Name
Name of the script. It contains a maximum of 128 characters. Only letters, digits, hyphens (-), underscores (_), and periods (.) are allowed.
NOTE:The name of the copied script cannot be the same as the name of the original script.
Select Directory
Parent directory of the script directory. The parent directory is the root directory by default.
- Click OK.
