Help Center/ DataArts Studio/ User Guide/ DataArts Factory/ Data Management/ (Optional) Creating a Database Schema
Updated on 2025-09-09 GMT+08:00
After creating a DWS data connection, you can manage the database schemas under the DWS data connection.
If existing database schemas meet your requirements, skip this section. Otherwise, create a database schema by following the instructions in this section.
- A DWS data connection has been created. For details, see Creating a Data Connection.
- A DWS database has been created. For details, see Creating a Database.
- Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
- On the DataArts Studio console, locate a workspace and click DataArts Factory.
- In the left navigation pane of DataArts Factory, choose .
- In the script development menu, click
. Expand a DWS data connection, select the database to be configured, and expand the directory level to schemas. Then right-click schemas and select Create Schema from the shortcut menu. - In the displayed dialog box, set the schema parameters based on Table 1.
- Click OK.
Related Operations
- Modify a database schema: In the script development menu, click
. Expand a data connection to the target database schema, right-click the database schema name, select Edit, and modify the database schema information. - Delete a database schema: In the script development menu, click
. Expand a data connection to the target database schema, right-click the database schema name, select Delete, and click OK in the displayed dialog box.
- The default database schema cannot be deleted.
- Deleted database schemas cannot be recovered. Exercise caution when performing this operation.
Parent topic: Data Management
