Creating a Database
After creating a data connection, you can create a database on the console or using a SQL script.
- (Recommended) Console: You can directly create a database on the DataArts Studio DataArts Factory console with no code.
- SQL script: You can also develop and execute a SQL script for creating a database in the SQL editor of DataArts Studio's DataArts Factory module or a data lake product, and then use the script to create a database.
This section describes how to create a database on the DataArts Factory console.
- You have already enabled the corresponding cloud services. for example, the MRS service.
- A data connection has been created. For details, see Creating a Data Connection.
- MRS API connections cannot be used to manage databases in a visualized mode. You are advised to create a database using SQL scripts.
- Before deleting a database, ensure that the database is not in use and is not associated with any data tables.
Creating a Database on the DataArts Factory Console
- Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
- On the DataArts Studio console, locate a workspace and click DataArts Factory.
- In the left navigation pane of DataArts Factory, choose .
- In the script development menu, click
. Right-click the data connection for which you want to create a database, and choose Create Database from the shortcut menu. Set the parameters based on Table 1.
Table 1 Creating a database Parameter
Mandatory
Database Name
Yes
Name of a database. The naming rules are as follows:
- DLI: The value must contain only numbers, letters, and underscores (_). It cannot start with an underscore (_) or contain only numbers.
- DWS: The value must contain only numbers, letters, and underscores (_). It cannot start with an underscore (_) or contain only numbers.
- MRS Hive: The value must contain 1 to 128 characters, including only letters, numbers, and underscores (_). It must start with a number or letter and cannot contain only numbers.
No
Descriptive information about the database. The requirements are as follows:
- DLI: The value contains a maximum of 256 characters.
- DWS: The value contains a maximum of 1,024 characters.
- MRS Hive: The value contains a maximum of 1,024 characters.
- Click OK.
Related Operations
- Modify a database: In the script development menu, click
. Expand a data connection, right-click a database name, select Edit, and modify the database information.
- Delete a database: In the script development menu, click
. Expand a data connection, right-click a database name, select Delete, and click OK in the displayed dialog box.
Deleted databases cannot be recovered. Exercise caution when performing this operation.
