Updated on 2026-01-28 GMT+08:00
Using an API Tool to Call an API Which Uses IAM Authentication
Before calling an API which uses IAM authentication, call the IAM API for obtaining a user token to obtain the token, which can be used for security authentication.
This section uses Postman as an example to describe how to use an API tool to call an API which uses IAM authentication. The procedure is as follows:
  1. Obtaining API Information: Prepare key information of the API.
  2. Obtaining a Token: Call the API for obtaining a user token to obtain the token.
  3. Calling an API: Use Postman to call the API.
  • Postman has been installed. If it has not been installed, download it from the Postman official website and install it.
Notes and Constraints
  • APIs which use IAM authentication authorized to apps of the IAM type can be called only using the token of the current account or those of its users, rather than any other account or user If needed, you can use a whitelist to authorize the APIs to other accounts. For details, see Authorizing an API Which Uses IAM Authentication Through a Whitelist.
  • To call an API in DataArts DataService locally, you need to bind an EIP to the DataArts DataService Exclusive cluster when creating the cluster.
  • The validity period of a token is 24 hours. If you use the same token for authentication, cache the token to prevent frequent API calls.
  • When an API in DataArts DataService is called, if the total duration of query and response exceeds 60 seconds (default value), a timeout error is reported. In this case, you can optimize the API configuration based on the API calling duration recorded in the access log.
    ____________Duration information__________
    duration: 60491ms //Total duration
    url_duration: 0ms //URL matching duration
    auth_duration: 70ms //Authentication duration
    before_sql_duration: 402ms //Preprocessing duration before SQL execution
    sql_duration: 60001ms //SQL execution duration
    after_sql_duration:18ms //Postprocessing duration after SQL execution
  1. Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
  2. On the DataArts Studio console, locate a workspace and click DataArts DataService.
  3. In the left navigation pane, choose an edition, for example, Exclusive Edition. The Overview page is displayed.
  4. Obtain the URL, request method, and input parameters of the API to be called.
    In the navigation pane on the left, choose APIs. Locate the API to be called, click the API name to access its details page, and record the URL, request method, and input parameters of the API.
    • URL for calling the API: The exclusive edition supports both private and public IP addresses. To use the public IP address, you need to bind an EIP to the cluster during cluster creation. If you want to call an API in DataArts DataService Exclusive locally, you need to use a public IP address to ensure network connectivity.
    • Input parameters: In this example, an API with various input parameter locations is created to describe how to enter various input parameters during an API call.
      Figure 1 Recording the URL, request method, and input parameters
Obtaining a Token
  1. Start Postman and add an API request.
  2. Use an API tool to call the API to obtain the token.
    When calling the API to obtain a user token, you must set auth.scope in the request body to project.
    In the request, POST https://IAM endpoint/v3/auth/tokens is the URL, and Content-Type: application/json is the message header. The content in {} is the request body.
    Configure the bold and italic parameters based on site requirements.
    • IAM endpoint indicates the endpoint of IAM.
      An endpoint is the request address for calling an API. Endpoints vary depending on services and regions. You can obtain endpoints from Regions and Endpoints.
    • username indicates the username, domainname indicates the account to which the user belongs, ******** indicates the login password, and xxxxxxxxxxxxxxxxxx indicates the project ID. To obtain the username, account name, and project ID, perform the following steps:
      1. Register with and log in to the management console.
      2. Hover the cursor on the username in the upper right corner and select My Credentials from the drop-down list.
      3. On the API Credentials page, obtain the account name, account ID, IAM username, and IAM user ID, and obtain the project and its ID from the project list.
        "auth": {
            "identity": {
                "methods": [
                    "password"
                "password": {
                    "user": {
                        "name": "username",
                        "password": "********",
                        "domain": {
                            "name": "domainname"
            "scope": {
                "project": {
                    "id": "xxxxxxxxxxxxxxxxxx"
    Figure 2 Obtaining a token by calling
  3. Obtain the value of x-subject-token in the response header, which is the user token. When calling an API, you can add the token to the request header to obtain the permission to call the API through identity authentication.
    Figure 3 Obtaining a token
Calling an API
  2. Configure the API request as follows:
    • Request method and calling URL: Obtain them by referring to Obtaining API Information. If input parameters include Path and Query parameters, you need to change the {path} variable in the API calling URL to the value of the Path parameter, and add the value of the Query parameter to the end of the API calling URL in the following format: ?Query parameter name=Query parameter value, for example, ?query=1 in this example.
      Figure 4 Request method and calling URL
    • Params: If the Query parameter has been added to the end of the calling URL in the ?Query parameter name=Query parameter value format, the value of Query Params is automatically generated. Otherwise, you need to enter a value.
      Figure 5 Params
      If you want to customize the calling result, set the following Query parameters:
      • (Optional) Pagination configuration: By default, the system assigns pagination data to the APIs created using configuration or a script/MyBatis. If you want to obtain specified pagination data, modify the following parameters. pageSize indicates the page size, and pageNum indicates the page number.
        Figure 6 Pagination parameters
        For APIs created using a script/MyBatis with custom pagination configuration, the pagination logic is written to the data acquisition SQL statement during API creation. Therefore, the pagination settings cannot be modified during an API call.
      • (Optional) Sorting configuration: By default, the system provides the default sorting based on the ranking parameters. By default, the custom ranking mode is ascending. To change the sorting, modify the pre_order_by parameter. The value of pre_order_by is in either of the following formats: Ranking parameter name:ASC (ascending order) or Ranking parameter name:DESC (descending order). Separate multiple ranking parameter descriptions by semicolons (;).
        Figure 7 Ranking parameters
        You can change the value of pre_order_by as follows:
        • Delete an optional ranking parameter. The parameter is no longer used for ranking.
        • Change the ranking mode of a ranking parameter whose ranking mode is custom to ascending or descending. The ranking parameter is sorted based on the new ranking mode.
        The value of pre_order_by cannot be changed in any of the following ways. Otherwise, the change does not take effect or an error is reported during API calling.
        • If a mandatory ranking parameter is deleted, the parameter is still used for ranking and the deletion does not take effect.
        • Adjustment of the sequence of ranking parameters will not take effect. The sequence of ranking parameters configured during the creation of an API through configuration, a script, or MyBatis will still be used.
        • If you change the ranking mode of a ranking parameter whose ranking mode is ascending or descending, the API cannot be called. Such a change is not allowed.
      • (Optional) Number of returned records: If Return Total Records is enabled during API creation, it takes a long time to obtain the total number of data records if the data table corresponding to the API contains a large amount of data. In this case, if you do not want the system to calculate and return the total number of data records during an API call, you can modify the use_total_num parameter. The use_total_num parameter specifies whether to calculate and return the total number of data records. If its value is 1, the total number of data records is returned. If its value is not 1, the total number of data records is not returned.
        Figure 8 Number of returned records
    • Headers: Enter the value of x-subject-token recorded in Obtaining a Token for X-Auth-Token, and enter parameter header and its value.
      By default, Postman automatically selects Host and generates a host value from the URI.
      Figure 9 Headers
    • Body: Select the raw format and use braces ({}) to enclose a string in "Body parameter name":Body parameter value format, for example, {"body":4} in this example.
      Figure 10 Body
  3. After configuring the API request, click Send to send a request to the server and check the returned result. If "errCode":"DLM.0" is returned, the API is successfully called. If the API call fails, rectify the fault based on the error message.
    If the API call fails and message "Could not get any response" is displayed, disable SSL certificate verification or proxy as prompted, and try again.
    Figure 11 Calling an API
