Configuring a Parallel Processing Operator
The Parallel Processing operator can execute multiple branches at the same time. The branches do not affect each other.
       Parameter  |
       Description  |
       Policy Upon Branch Failure  |
       Policy for processing the API workflow when one of the parallel branches fails
       Branch 1  |
       Timeout Duration (ms)  |
       If the execution of the current branch times out, the branch status becomes failed. The default value is 0, indicating that there is no time limit.  |
       Branch 2  |
       Branch n  |
