Configuring an Entry API Operator
An API workflow starts with the Entry API operator. After the API workflow is published, it can be invoked through the Entry API operator. In the Entry API operator, you need to define the API workflow name, URL, parameter protocol, request method, reviewer, security authentication, and request parameters.
Parameter |
Descriptions |
API |
Entry API name, that is, API workflow name An API name consists of 3 to 64 characters and starts with a letter. Only letters, numbers, and underscores (_) are allowed. |
Request Path |
Entry API access path, that is, API workflow access path, for example, /getUserInfo
It is the part between the domain name and query parameters in the URL of a request path, for example, /blogs/xxxx shown in the following figure.
Figure 1 API access path in the URL
![]() Braces ({}) can be used to identify parameters in a request path as wildcard characters. For example, /blogs/{blog_id} indicates that any parameter can follow /blogs. /blogs/188138 and /blogs/0 can both match /blogs/{blog_id}, and are processed by this API. In addition, duplicate request paths are not allowed for the same domain name. When a path parameter is used as a wildcard, the name is not unique. For example, /blogs/{blog_id} and /blogs/{xxxx} are considered as the same path. |
Protocol |
Protocol used to transmit requests. The exclusive edition supports HTTPS. HTTPS is recommended. It is an HTTP-based protocol with SSL or TLS encryption verification. It can effectively verify identities and protect data integrity. |
Request Method |
HTTP request method, indicating the type of the requested operation, such as GET and POST. The method complies with the resultful style.
Description |
A brief description of the API to create. |
Tags |
API tag. The tag is used to mark the API attributes. After the API is created, you can quickly search for the API by tag. A maximum of 20 tags can be set for an API. |
Reviewers |
A reviewer who has permissions to review APIs. Click Add to enter the page and click Add on the Reviewers tab page to add a reviewer. |
Security Authentication |
When creating an API, you can select one of the following security authentication modes. The three modes differ in how the API is called. You are advised to select App authentication, which is more secure that the other two modes.
Display Scope |
After the API is published, all users in the selected scope can view the API in the service catalog.
Access Log |
If this parameter is selected, you can view the generated API query results in Operations Management > Access Logs. The results are retained for seven days. |
Min. Retention Period |
Minimum retention period of the API publishing status, in hours. Value 0 indicates that the retention period is not limited. You can suspend, unpublish, or cancel authorization for an API only after the minimum retention period ends. The system notifies the authorized users. If all authorized users have processed the notifications or unbound the API from their apps, the API will be suspended or unpublished, or the API authorization will be canceled. Otherwise, the system will forcibly suspend, unpublish, or cancel authorization for the API when the minimum retention periods ends. For example, if the minimum retention period is set to 24 hours, the API can be suspended 24 hours after it is published. If the authorized user handles the notifications in the review center or unbind the API from the app, the API will be directly suspended. Otherwise, the API will be forcibly suspended when the minimum retention period ends. |
Input Parameters |
Parameters required for invoking the API workflow.
An input parameter consists of the parameter location, parameter type, whether the parameter is mandatory, whether a null value is allowed, and the default value.
When defining an input parameter, ensure that the following size requirements are met:
You need to set input parameters based on the designed request parameters for the API workflow. For example, the request path of the API workflow used to query user information in multiple tables by user ID is /getUserInfo. You can configure input parameters as follows:
