Updated on 2025-09-09 GMT+08:00
Synchronizing APIs
Operation Scenario
You can synchronize APIs from DataArts DataService Exclusive to Data Map.
An API has been created.
Synchronizing APIs to Data Map
  1. On the DataArts Studio console, locate a workspace and click DataArts DataService.
  2. In the left navigation pane, choose an edition, for example DataArts DataService Exclusive, to access the Overview page.
  3. Choose API Development > APIs.
  4. Select the target APIs, click More above the API list, and select Synchronize to Data Maps.
    Figure 1 More operations
  5. On the Synch Result page, check the API synchronization status and details.
    Figure 2 Synchronization result
    • Only published APIs can be synchronized to Data Map.
    • Only APIs of the following data sources can be synchronized: DLI, DWS, HBase, and ClickHouse.
