Debugging an API
You can debug an API on the management console by adding HTTP header parameters and body parameters.
- APIs whose backend paths contain environment variables cannot be debugged.
- APIs bound to a signature key cannot be debugged.
- If a request throttling policy has been bound to an API, the policy does not take effect when you debug the API.
An API has been created.
- On the DataArts Studio console, locate a workspace and click DataArts DataService.
- In the left navigation pane, choose an edition, for example, Exclusive Edition. The Overview page is displayed.
- Choose .
- Use either of the following methods to debug an API:
- Locate the row that contains the target API, and choose .
- Click the name of the target API, and click Test on the displayed API details page. You can configure API request parameters in the left pane. See Table 1 for parameter details. The request information sent by the API and the returned result after the API request is invoked are displayed on the right.
Table 1 Debugging APIs Parameter
API Version
Only specified API versions in DataArts DataService Exclusive can be debugged.
If the API version is not specified, unpublished APIs will be debugged by default.
Parameters
Query parameters and their values.
Cluster Settings
Supported only by Exclusive Edition. Select the instance where the API to be debugged resides.
The information displayed on the debugging page varies according to the request type.
- After request parameters are added, click Debug.
The API calling response information is displayed in the command output area in the right pane.
- If the API is successfully called, HTTP status code 200 and response information are returned.
- If no result is returned within 60 seconds (default value), a timeout error is reported.
- If the debugging fails, the HTTP status code 4xx or 5xx is returned.
- You can send different requests using varied parameters and values to verify the API.
To modify the API parameters, click Edit in the upper right corner. The API editing page is displayed.
Related Operations
- Debugging APIs: On the DataArts DataService Exclusive console, choose API Management > APIs in the navigation pane on the left. In the right pane, select APIs, click Batch Operation above the list, and select Debug. On the displayed page, import the Excel file with the modified API debugging parameters. Figure 1 Batch operation
- Publishing an API: After debugging an API, you can publish it so that it can be called by API callers. For details, see Publishing an API.
