Updated on 2026-08-21 GMT+08:00
Supported Data Types
To ensure that data is completely imported to the migration destination, correctly configure field mappings based on data types supported for different data sources. For details, see Table 1.
Types of Data That Can Be Migrated from a MySQL Database
When the source end is a MySQL database and the destination end is a Hive or DWS database, the following data types are supported:
Table 2 Data types supported for the open-source MySQL database
Category
Type
Storage Format Example
Hive
DWS
Character string
CHAR(M)
A fixed-length string of 1 to 255 characters, for example, CHAR(5). The string is padded to a specified length with spaces.
The length limit is not mandatory. It is set to 1 by default.
'a' or 'aaaaa'
CHAR
CHAR
VARCHAR(M)
A variable-length string of 1 to 255 characters (more than 255 characters for MySQL of a later version), for example, VARCHAR(25).
When creating a field of the VARCHAR type, you must define the length.
'a' or 'aaaaa'
VARCHAR
VARCHAR
Value
DECIMAL(M,D)
Uncompressed floating-point numbers cannot be unsigned. In unpacking decimals, each decimal corresponds to a byte.
Defining the number of display lengths (M) and decimals (D) is required. NUMERIC is the synonym of DECIMAL.
52.36
DECIMAL
When D is 0, it corresponds to BIGINT.
When D is not 0, it corresponds to NUMERIC.
NUMERIC
Same as DECIMAL
DECIMAL
NUMERIC
INTEGER
An integer of normal size that can be signed. If the value is signed, it ranges from -2147483648 to 2147483647.
If the value is unsigned, the value ranges from 0 to 4294967295. Up to 11-bit width can be specified.
5236
INT
INTEGER
INTEGER UNSIGNED
Unsigned form of INTEGER
BIGINT
INTEGER
INT
Same as INTEGER
5236
INT
INTEGER
INT UNSIGNED
Same as INTEGER UNSIGNED
BIGINT
INTEGER
BIGINT
A large integer that can be signed. If the value is signed, it ranges from -9223372036854775808 to 9223372036854775807. If the value is unsigned, the value ranges from 0 to 18446744073709551615. Up to 20-bit width can be specified.
5236
BIGINT
BIGINT
BIGINT UNSIGNED
Unsigned form of BIGINT
BIGINT
BIGINT
MEDIUMINT
A medium-sized integer that can be signed. If the value is signed, it ranges from -8388608 to 8388607.
If the value is unsigned, it ranges from 0 to 16777215, and you can specify a maximum of 9-bit width.
-128 to 127
INT
INTEGER
MEDIUMINT UNSIGNED
Unsigned form of MEDIUMINT
BIGINT
INTEGER
TINYINT
A very small integer that can be signed. If signed, the value ranges from -128 to 127.
If unsigned, the value ranges from 0 to 255, and you can specify a maximum of 4-bit width.
100
TINYINT
SMALLINT
TINYINT UNSIGNED
Unsigned form of TINYINT
TINYINT
SMALLINT
BOOL
The bool of MySQL is tinyint(1).
-128, 127
SMALLINT
BYTEA
SMALLINT
A small integer that can be signed. If the value is signed, it ranges from -32768 to 32767.
If unsigned, the value ranges from 0 to 65535, and you can specify a maximum of 5-bit width.
9999
SMALLINT
SMALLINT
SMALLINT UNSIGNED
Unsigned form of SMALLINT
INT
SMALLINT
REAL
Same as DOUBLE
DOUBLE
FLOAT(M,D)
Unsigned floating-point numbers cannot be used. The display length (M) and number of decimal places (D) can be specified. They are not mandatory, and their default values are 10 and 2, respectively. In the preceding information, 2 indicates the number of decimal places and 10 indicates the total number of digits (including decimal places). The decimal precision can reach 24 floating points.
52.36
FLOAT
FLOAT4
DOUBLE(M,D)
Unsigned double-precision floating-point numbers cannot be used. The display length (M) and number of decimal places (D) can be specified. This is not mandatory.
The default value is 16,4, where 4 is the number of decimal places. The decimal precision can reach 53-digit. REAL is a synonym of DOUBLE.
52.36
DOUBLE
FLOAT8
DOUBLE PRECISION
Similar to DOUBLE
52.3
DOUBLE
FLOAT8
Bit
BIT(M)
Stored bit type value. BIT(M) can store up to M bits of values, and M ranges from 1 to 64.
B'1111100' B'1100'
TINYINT
BYTEA
Time and date
DATE
The value is in the YYYY-MM-DD format and ranges from 1000-01-01 to 9999-12-31. For example, December 30, 1973 will be stored as 1973-12-30.
1999-10-01
DATE
TIMESTAMP
TIME
Stores information about the hour, minute, and second.
'09:10:21' or '9:10:21'
Not supported (string)
TIME
DATETIME
The date and time are in the YYYY-MM-DD HH:MM:SS format and range from 1000-01-01 00:00:00 to 9999-12-31 23:59:59. For example, 3:30 p.m. on December 30, 1973 will be stored as 1973-12-30 15:30:00.
'1973-12-30 15:30:00'
TIMESTAMP
TIMESTAMP
TIMESTAMP
Timestamp type. Timestamp between midnight on January 1, 1970 and a time point in 2037. Similar to the DATETIME format (YYYYMMDDHHMMSS), except that no hyphen is required. For example, 3:30 p.m. December 30, 1973 will be stored as 19731230153000.
19731230153000
TIMESTAMP
TIMESTAMP
YEAR(M)
The year is stored in 2-digit or 4-digit number format. If the length is specified as 2 (for example, YEAR(2)), the year ranges from 1970 to 2069 (70 to 69). If the length is specified as 4, the year ranges from 1901 to 2155. The default length is 4.
2000
Not supported
Multimedia (binary)
BINARY(M)
The number of bytes is M. The length of a variable-length binary string ranges from 0 to M. M is the value length plus 1.
0x2A3B4058 (binary data)
Not supported
BYTEA
VARBINARY(M)
The number of bytes is M. A fixed binary string with a length of 0 to M.
0x2A3B4059 (binary data)
Not supported
BYTEA
TEXT
The maximum length of the field is 65535 characters. TEXT is a "binary large object" and is used to store large binary data, such as images or other types of files.
0x5236 (binary data)
Not supported
Not supported
TINYTEXT
A binary string of 0 to 255 bytes in short text
Not supported
MEDIUMTEXT
A binary string of 0 to 167772154 bytes in medium-length text
Not supported
LONGTEXT
A binary string of 0 to 4294967295 bytes in large-length text
Not supported
BLOB
The maximum length of the field is 65535 characters. BLOB is a "binary large object" and is used to store large binary data, such as images or other types of files. BLOB is case-sensitive.
Not supported
Supported
TINYBLOB
Not supported
Supported
MEDIUMBLOB
Not supported
Supported
LONGBLOB
Not supported
Supported
Special type
SET
SET is a string object that can have no or multiple values. The values come from the allowed column of values specified when the table is created. When specifying the SET column values that contain multiple SET members, separate the members with commas (,). The SET member value cannot contain commas (,).
Not supported
JSON
Not supported
Not supported (TEXT)
ENUM
When an ENUM is defined, a list of its values is created, which are the items that must be used for selection (or NULL). For example, if you want a field to contain "A", "B", or "C", you can define an ENUM ("A", "B", or "C"). Only these values (or NULL) can be used to fill in the field.
Not supported
Not supported
Types of Data That Can Be Migrated from an Oracle Database
When the source end is an Oracle database and the destination end is a Hive or DWS database, the following data sources are supported:
Table 3 Data types supported for the Oracle database
Category
Type
Hive
DWS
Character string
char
Fixed-length character string, which is padded with spaces to reach the maximum length.
CHAR
CHAR
nchar
Fixed-length character string contains data in Unicode format.
CHAR
CHAR
varchar2
Synonym of VARCHAR. It is a variable-length string, unlike the CHAR type, which does not pad the field or variable to reach its maximum length with spaces.
VARCHAR
VARCHAR
nvarchar2
Variable-length character string contains data in Unicode format.
VARCHAR
VARCHAR
Value
number
Stores numbers with a precision of up to 38 digits.
DECIMAL
NUMERIC
binary_float
32-bit single-precision floating point number
FLOAT
FLOAT8
binary_double
64-bit double-precision floating point number
DOUBLE
FLOAT8
long
A maximum of 2 GB character data can be stored.
Not supported
Not supported
Time and date
date
7-byte date/time data type, including seven attributes: century, year in the century, month, day in the month, hour, minute, and second.
DATE
TIMESTAMP
timestamp
7-byte or 11-byte fixed-width date/time data type that contains decimals (seconds)
TIMESTAMP
TIMESTAMP
timestamp with time zone
3-byte timestamp, which supports the time zone.
TIMESTAMP
TIME WITH TIME ZONE
timestamp with local time zone
7-byte or 11-byte fixed-width date/time data type. Time zone conversion occurs when data is inserted or read.
TIMESTAMP
interval year to month
5-byte fixed-width data type, which is used to store a time segment.
Not supported
interval day to second
11-byte fixed-width data type, which is used to store a time segment. The time segment is stored in days/hours/minutes/seconds. The value can also contain nine decimal places (seconds).
Not supported
Multimedia (binary)
raw
A variable-length binary data type. Character set conversion is not performed for data stored in this data type.
Not supported
Supported
long raw
Stores up to 2 GB binary information.
Not supported
Supported
blob
A maximum of 4 GB data can be stored.
Not supported
Supported
clob
In Oracle 10g and later versions, a maximum of (4 GB) x (database block size) bytes of data can be stored. CLOB contains the information for which character set conversion is to be performed. This data type is ideal for storing plain text information.
String
Not supported
nclob
This type can store a maximum of 4 GB data. When the character set is converted, this type is affected.
Not supported
Not supported
bfile
An Oracle directory object and a file name can be stored in the database column, and the file can be read through the Oracle directory object and file name.
Not supported
Not supported
rowid
It is the address of a row in the database table. It is 10 bytes long.
Not supported
Not supported
urowid
It is a common row ID and does not have a fixed rowid table.
Not supported
Not supported
xml
It is used to store data in XML format.
Not supported
Not supported
Types of Data That Can Be Migrated from a SQL Server Database
When the source end is a SQL Server database and the destination end is a Hive, Oracle or DWS database, the following data sources are supported:
Table 4 Data types supported for the SQL Server database
Category
Type
Hive
DWS
Oracle
String data type
char
CHAR
CHAR
CHAR
nchar
CHAR
CHAR
CHAR
varchar
A variable-length string consists of 1 to 255 characters (more than 255 characters for MySQL of a later version). Example: VARCHAR(25). When creating a field of the VARCHAR type, you must define the length.
VARCHAR
VARCHAR
VARCHAR
nvarchar
Stores variable-length Unicode character data, similar to varchar.
VARCHAR
VARCHAR
VARCHAR
Numeric data type
int
int is stored in four bytes, where one binary bit represents a sign bit, and the other 31 binary bits represent a length and a size, and may represent all integers ranging from –231 to 231 – 1.
INT
INTEGER
INT
bigint
bigint is stored in eight bytes, where one binary bit represents a sign bit, and the other 63 binary bits represent a length and a size, and may represent all integers ranging from –263 to 263 – 1.
BIGINT
BIGINT
NUMBER
smallint
Data of the smallint type occupies two bytes of storage space. One binary bit indicates a positive or negative sign of an integer value, and the other 15 binary bits indicate a length and a size, and may represent all integers ranging from –215 to 215 – 1.
SMALLINT
SMALLINT
NUMBER
tinyint
Tinyint data occupies one byte of storage space and can represent all integers ranging from 0 to 255.
TINYINT
TINYINT
NUMBER
real
The value can be a positive or negative decimal number.
DOUBLE
FLOAT4
NUMBER
float
The number of digits (in scientific notation) of the mantissa of a float value, which determines the precision and storage size
FLOAT
FLOAT8
binary_float
decimal
Numeric data type with fixed precision and scale
DECIMAL
NUMERIC
NUMBER
numeric
Stores zero, positive, and negative fixed point numbers.
DECIMAL
NUMERIC
NUMBER
Date and time data type
date
Stores date data represented by strings.
DATE
TIMESTAMP
DATE
time
Time of a day, which is recorded in the form of a character string.
TIME
Not supported
datetime
Stores time and date data.
TIMESTAMP
TIMESTAMP
Not supported
datetime2
Extended type of datetime, which has a larger data range. By default, the minimum precision is the highest, and the user-defined precision is optional.
TIMESTAMP
TIMESTAMP
Not supported
smalldatetime
The smalldatetime type is similar to the datetime type. The difference is that the smalldatetime type stores data from January 1, 1900 to June 6, 2079. When the date and time precision is low, the smalldatetime type can be used. Data of this type occupies 4-byte storage space.
TIMESTAMP
TIMESTAMP
Not supported
datetimeoffset
A time that uses the 24-hour clock and combined with date and the time zone.
TIMESTAMP
Not supported
Multimedia data types
(binary)
text
Stores text data.
Not supported
ntext
The function of this type is the same as that of the text type. It is Unicode data with variable length.
Not supported
Variable-length binary data used to store pictures, catalog pictures, or paintings.
Not supported
binary
Binary data with a fixed length of n bytes, where n ranges from 1 to 8,000.
Not supported
varbinary
Not supported
Currency data type
money
Stores currency values.
Not supported
smallmoney
Similar to the money type, a currency symbol is prefixed to the input data. For example, the currency symbol of USD is $.
Not supported
Data type
bit
Bit data type. The value is 0 or 1. The length is 1 byte. A bit value is often used as a logical value to determine whether it is true(1) or false(0). If a non-zero value is entered, the system replaces it with 1.
Not supported
Not supported
Not supported
Other data types
rowversion
Each piece of data has a counter. The value of the counter increases when an insert or update operation is performed on a table that contains the rowversion column in the database.
Not supported
Not supported
Not supported
uniqueidentifier
A 16-byte globally unique identifier (GUID) is a unique number generated by the SQL Server based on the network adapter address and host CPU clock. Each bit is a hexadecimal character ranging from 0 to 9 or a to f.
Not supported
Not supported
Not supported
cursor
Cursor data type
Not supported
Not supported
Not supported
sql_variant
Stores any valid SQL Server data except the text, image, and timestamp data, which facilitates the development of the SQL Server.
Not supported
Not supported
Not supported
table
Stores the result set after a table or view is processed.
Not supported
Not supported
Not supported
xml
Data type of the XML data. XML instances can be stored in columns or variables of the XML type. The stored XML instance size cannot exceed 2 GB.
Not supported
Not supported
Not supported
Types of Data That Can Be Migrated from a PostgreSQL Database
When the source end is a PostgreSQL database and the destination end is Hive, DLI, or DWS, the following data types are supported:
Table 5 Data types supported for the PostgreSQL database
Category
Type
Hive
DWS
DLI
Character
char
Fixed-length string, which is padded to a specified length with spaces on the right.
CHAR
CHAR
varchar
Variable-length string. Fields or variables are not padded to the maximum length with spaces.
VARCHAR
VARCHAR
Numeric
smallint
The extension name int2 is stored in two bytes and ranges from –32768 to 32767.
SMALLINT
SMALLINT
SMALLINT
int
The extension name int4 is stored in four bytes and ranges from –2147483648 to 2147483647.
INTEGER
INT
INT
bigint
The extension name int8 is stored in eight bytes and ranges from –9223372036854775808 to 9223372036854775807.
BIGINT
BIGINT
BIGINT
decimal(p,s)
The precision p represents the number of valid digits stored in the value, and the scale s represents the number of digits after the decimal point that can be stored. The maximum value of p is 1000.
DECIMAL(P,S)
DECIMAL(P,S)
DECIMAL(P,S)
float
4-byte or 8-byte storage. float(n): For the single precision, the value of n ranges from 1 to 24, the number of valid precision digits is 6, and the length is four bytes. For the double precision, the value of n ranges from 25 to 53, the number of valid precision digits is 15, and the length is 8 bytes.
FLOAT/DOUBLE
FLOAT/DOUBLE
FLOAT/DOUBLE
smallserial
Sequence data type, which is stored in smallint format
SMALLINT
SMALLINT
SMALLINT
serial
Sequence data type, which is stored in int format
INTEGER
INT
INT
bigserial
Sequence data type, which is stored in bigint format
BIGINT
BIGINT
BIGINT
Time and date
date
Stores the date.
DATE
DATE
DATE
timestamp
Stores date and time data without time zones.
TIMESTAMP
TIMESTAMP
timestamptz
Stores the date and time, including the time zone.
TIMESTAMP
TIMESTAMPZ
time
Time within one day, excluding the time zone
TIME
timez
Time within one day, including the time zone
TIMEZ
interval
Time interval
Bit string
bit
Fixed-length string, for example, b'000101'
varbit
Variable-length string, for example, b'101'
Currency type
money
The value is stored in eight bytes and ranges from –922337203685477.5808 to 922337203685477.5807.
DOUBLE
MONEY
DECIMAL(P,S)
Boolean
boolean
The value is stored in one byte and can be 1, 0, or NULL.
BOOLEAN
BOOLEAN
BOOLEAN
Text type
text
Variable-length text without a length limit
Multimedia (binary)
bytea
Variable-length binary string. It is a native PostgreSQL binary type, with a maximum size of about 1 GB. It stores the original byte sequence in hexadecimal format with the \x prefix (for example, \x414243).
bytea
Types of Data That Can Be Migrated from a DWS Database
If the migration source is a DWS database, the following data types are supported.
Table 6 Data types supported for the DWS database
Category
Type
Character
char
varchar
Value
double
Stores double-precision floating-point numbers.
decimal(p,s)
numeric
real
Same as double
int
bigint
smallint
tinyint
Time and date
date
Stores the date.
timestamp
time
Bit string
bit
Boolean
boolean
Text type
text
Multimedia (binary)
bytea
blob
Binary large object. Column storage does not support the BLOB type. The maximum size is about 1 GB.
raw
Variable-length hexadecimal type. Column storage does not support the RAW type. The maximum size is about 1 GB.
Types of Data That Can Be Migrated from a ShenTong Database
When the source is a ShenTong database and the destination is MRS Hive or MRS Hudi, the following data types are supported.
Table 7 Data types supported for the ShenTong database
Category
Type
MRS Hive
MRS Hudi
Character
VARCHAR
Stores specified fixed-length character strings.
'a' or 'aaaaa'
VARCHAR(765)
STRING
BPCHAR
Stores specified variable-length character strings.
'a' or 'aaaaa'
VARCHAR(765)
STRING
Value
NUMERIC
52.36
DECIMAL(10, 0)
DECIMAL(18, 0)
INT
5236
INT
INT
BIGINT
Stores signed integers. Integer part: 19 digits; decimal part: 0 digits
5236
BIGINT
BIGINT
TINYINT
Stores signed integers. Integer part: 3 digits; decimal part: 0 digits
100
SMALLINT
INT
BINARY
Stores fixed-length binary data.
0x2A3B4058
Not supported
FLOAT
VARBINARY
Stores variable-length binary data.
0x2A3B4058
Not supported
BINARY
FLOAT
Stores floating-point numbers with binary precision.
52.36
FLOAT
FLOAT
DOUBLE
52.3
DOUBLE
DOUBLE
Time and date
DATE
Stores information about the year, month, and day.
'1999-10-01', '1999/10/01', or '1999.10.01'
DATE
DATE
TIME
STRING
STRING
TIMESTAMP
Stores information about the year, month, day, hour, minute, and second.
'2002-12-12 09:10:21', '2002-12-12 9:10:21', '2002/12/12 09:10:21', or '2002.12.12 09:10:21'
TIMESTAMP
TIMESTAMP
Multimedia
CLOB
Stores variable-length binary large objects with a maximum length of 2 GB minus 1 byte.
STRING
STRING
BLOB
Not supported
BINARY
Boolean
BOOLEAN
BOOLEAN
BOOLEAN
Types of Data That Can Be Migrated from an SAP HANA Database
If the source is an SAP HANA database, the following data types are supported.
Table 8 Data types supported for the SAP HANA database
Category
Type
Character
VARCHAR
Stores variable-length strings.
NVARCHAR
TEXT
Stores long character strings. The maximum length of a character string is 2 GB minus 1 byte. Long text strings are stored.
Value
BIGINT
TINYINT
SMALLINT
REAL
DECIMAL
FLOAT
DOUBLE
Time and date
DATE
TIME
TIMESTAMP
Multimedia
CLOB
NCLOB
Boolean
BOOLEAN
Types of Data That Can Be Migrated from a DLI Database
If the migration source is a DLI database, the following data types are supported.
Table 9 Data types supported for the DLI database
Category
Type
Character
CHAR
VARCHAR
Same as CHAR
STRING
Value
BIGINT
TINYINT
SMALLINT
INT
Stores signed integers. Integer part: 10 digits; decimal part: 0 digits
DECIMAL
FLOAT
DOUBLE
Time and date
DATE
TIMESTAMP
Boolean
BOOLEAN
Types of Data That Can Be Migrated from an Elasticsearch/CSS Database
If the migration source is an Elasticsearch/CSS database, the following data types are supported.
Table 10 Data types supported for the Elasticsearch/CSS database
Category
Type
MySQL
Character
keyword
Stores strings.
"keyword"
String
text
"long string"
TEXT
string
"a string"
String
Integer
short
Stores 16-bit signed integers ranging from –32768 to 32767.
32765
smallInt
integer
Stores 32-bit signed integers ranging from –231 to 231 – 1.
3276566
int
long
Stores 64-bit signed integers ranging from –263 to 263 – 1.
3276566666
BIGINT
Value
double
64-bit IEEE 754 double-precision floating-point format
21.333
double
float
32-bit IEEE 754 single-precision floating-point format
21.333
double
Boolean
boolean
Boolean
Object
object
A string of flat storage objects
{"users.name":["John","Smith"],
users.age":[26,28],
"users.gender":[1, 2]}
TEXT
Nested
nested
A string of nested storage objects
{"users.name" : "John" ,
"users.age" : 26,
"users.gender" : 1}
{ "users.name" : "Smith",
"users.age" : 28,
"users.gender" : 2}
TEXT
Date
date
A string in the date format
"2018-01-13" or "2018-01-13 12:10:30"
DATE or timeStamp
Special type
ip
A string in the IP address format
"192.168.127.100"
String
Array
string_array
An array of strings
["str","str"]
TEXT
short_array
An array of 16-bit integers
[1,1,1]
TEXT
integer_array
An array of 32-bit integers
[1,1,1]
TEXT
long_array
An array of 64-bit integers
[1,1,1]
TEXT
float_array
An array of 32-bit floating-point numbers
[1.0,1.0,1.0]
TEXT
double_array
An array of 64-bit floating-point numbers
[1.0,1.0,1.0]
TEXT
Value range
completion
A string that is automatically completed
"string"
TEXT
Types of Data That Can Be Migrated from a Doris Database
If the migration source is a Doris database, the following data types are supported.
Table 11 Data types supported for the Doris database
Category
Type
String
CHAR(M)
Range: char[(length)]. A fixed-length string of 1 to 255 characters (1 by default).
VARCHAR(M)
Range: varchar(length). A variable-length string of 1 to 65,535 characters.
Value
DECIMAL(M,D)
Value type
TINYINT
Length: 1-byte signed integer
Range: [-128, 127]
SMALLINT
Length: 2-byte signed integer
Range: [-32768, 32767]
INT
Length: 4-byte signed integer
Range: [-2147483648, 2147483647]
BIGINT
Length: 8-byte signed integer
Range: [-9223372036854775808, 9223372036854775807]
LARGEINT
Length: 16-byte signed integer
Range: [-2^127, 2^127-1]
FLOAT
Length: 4-byte floating point number
Range: -3.40E+38 to +3.40E+38
DOUBLE
Length: 8-byte floating point number
Range: -1.79E+308 to +1.79E+308
DECIMAL[M,D]
Decimal type that ensures precision. M indicates the total number of valid digits, and D indicates the maximum number of digits after the decimal point. The range of M is [1,27], and that of D is [1,9]. In addition, M must be greater than or equal to D. The default value is decimal[10,0].
Precision: 1–27
Scale: 0–9
Date
DATE
Range: ['1000-01-01', '9999-12-31']. The default printing format is 'YYYY-MM-DD'.
DATETIME
Range: ['1000-01-01 00:00:00', '9999-12-31 00:00:00']. The default printing format is 'YYYY-MM-DD HH:MM:SS'.
Special type
HLL
HyperLogLog (HLL) is a binary type. It can be used only for aggregation tables, and the aggregation type must be HLL_UNION.
This type is mainly used to pre-aggregate data in non-accurate and fast deduplication scenarios.
HLL columns can be queried or used only using hll_union_agg, hll_cardinality, or hll_hash.
BITMAP
BITMAP is a binary type. It can be used only for aggregation tables, and the aggregation type must be BITMAP_UNION.
This type is mainly used to pre-aggregate data in accurate deduplication scenarios. It can also be used to store user IDs in user profile scenarios.
BITMAP columns can be queried or used only using BITMAP functions.
Types of Data That Can Be Migrated from a Dameng Database
When the source end is a Dameng database and the destination end is a Hive or DWS database, the following data types are supported.
Table 12 Data types supported for the Dameng database
Category
Type
Hive
DWS
Character
CHAR
'a' or 'aaaaa'
CHAR
CHAR
CHARACTER
Same as CHAR
'a' or 'aaaaa'
CHAR
CHAR
VARCHAR
'a' or 'aaaaa'
VARCHAR
VARCHAR
VARCHAR2
Same as VARCHAR
'a' or 'aaaaa'
VARCHAR
VARCHAR
Value
NUMERIC
52.36
DECIMAL
NUMERIC
DECIMAL
Similar to NUMERIC
52.36
DECIMAL
NUMERIC
DEC
Same as DECIMAL
52.36
DECIMAL
NUMERIC
INTEGER
5236
INT
INTEGER
INT
Same as INTEGER
5236
INT
INTEGER
BIGINT
5236
BIGINT
BIGINT
TINYINT
100
TINYINT
SMALLINT
SMALLINT
Stores signed integers. Integer part: 5 digits; decimal part: 0 digits
9999
SMALLINT
SMALLINT
BYTE
Similar to TINYINT. Integer part: 3 digits; decimal part: 0 digits
100
TINYINT
SMALLINT
BINARY
0x2A3B4058
BINARY (NULL)
BYTEA (NULL)
VARBINARY
0x2A3B4058
BINARY (NULL)
BYTEA (NULL)
FLOAT
52.36
FLOAT
FLOAT8
DOUBLE
Similar to FLOAT
52.36
DOUBLE
FLOAT8
REAL
Stores binary floating-point numbers.
52.3
FLOAT
FLOAT4
DOUBLE PRECISION
52.3
DOUBLE
FLOAT8
Bit string
BIT
Stores 1, 0, or NULL.
1, 0, or NULL
TINYINT(1 0 NULL)
BOOLEAN (true false NULL)
Time and date
DATE
DATE
TIMESTAMP
TIME
TIME
TIMESTAMP
TIMESTAMP
TIMESTAMP
TIME WITH TIME ZONE
Stores a TIME value with a time zone. Add the time zone information to the end of the TIME type.
'09:10:21 +8:00', '09:10:21+8:00', or '9:10:21+8:00'
TIME WITH TIME ZONE
TIMESTAMP WITH TIME ZONE
Stores a TIMESTAMP value with a time zone. Add the time zone information to the end of the TIMESTAMP type.
'2002-12-12 09:10:21 +8:00', '2002-12-12 9:10:21 +8:00', '2002/12/12 09:10:21 +8:00', or '2002.12.12 09:10:21 +8:00'
TIMESTAMP
TIMESTAMP WITH LOCAL TIME ZONE
Stores the TIMESTAMP value of a local time zone. The standard time zone type (TIMESTAMP WITH TIME ZONE) can be converted to the local time zone type.
DATETIME WITH TIME ZONE
Same as TIMESTAMP WITH TIME ZONE
TIMESTAMP
INTERVAL YEAR
Interval of years. The leading precision specifies the range of years.
INTERVAL '0015' YEAR
Not supported (VARCHAR)
INTERVAL YEAR TO MONTH
Interval of months and years. The leading precision specifies the range of years.
INTERVAL '0015-08' YEAR TO MONTH
INTERVAL MONTH
Interval of months. The leading precision specifies the range of months.
INTERVAL '0015' MONTH
INTERVAL DAY
Interval of days. The leading precision specifies the range of days.
INTERVAL '150' DAY
INTERVAL DAY TO HOUR
Interval of hours and days. The leading precision specifies the range of days.
INTERVAL '9 23' DAY TO HOUR
INTERVAL DAY TO MINUTE
Interval of minutes, hours, and days. The leading precision specifies the range of days.
INTERVAL '09 23:12' DAY TO MINUTE
INTERVAL DAY TO SECOND
Interval of seconds, minutes, hours, and days. The leading precision specifies the range of days.
INTERVAL '09 23:12:01.1' DAY TO SECOND
INTERVAL HOUR
Interval of hours. The leading precision specifies the range of hours.
INTERVAL '150' HOUR
INTERVAL HOUR TO MINUTE
Interval of minutes and hours. The leading precision specifies the range of hours.
INTERVAL '23:12' HOUR TO MINUTE
INTERVAL HOUR TO SECOND
Interval of seconds, minutes, and hours. The leading precision specifies the range of hours.
INTERVAL '23:12:01.1' HOUR TO SECOND
INTERVAL MINUTE
Interval of minutes. The leading precision specifies the range of minutes.
INTERVAL '150' MINUTE
INTERVAL MINUTE TO SECOND
Interval of minutes and seconds. The leading precision specifies the range of minutes.
INTERVAL '12:01.1' MINUTE TO SECOND
INTERVAL SECOND
Interval of seconds. The leading precision specifies the value range of the integer part of the second
INTERVAL '51.1' SECOND
Multimedia
IMAGE specifies the image type in the multimedia information.
An image consists of a pixel lattice with a maximum length of 2 GB minus 1 byte. In addition to storing image data, other binary data can also be stored.
Not supported
Not supported
LONGVARBINARY
Same as IMAGE
Not supported
Not supported
TEXT
Stores the long string type.
The maximum length of a string is 2 GB minus 1 byte.
Not supported
Not supported
LONGVARCHAR
Similar to TEXT
Not supported
Not supported
BLOB
Not supported
Not supported
CLOB
Not supported
Not supported
BFILE
Specified the binary files stored in the operating systems.
Files are stored in the operating systems instead of the databases. They can be read only.
Not supported
Not supported
Types of Data That Can Be Migrated from an IBM Db2 Database
If the source is an IBM Db2 database, the following data types are supported.
Table 13 Data types supported for the IBM Db2 database
Category
Type
Numeric
BIGINT
Value range: [-9 223 372 036 854 775 808, 9 223 372 036 854 775 807]
SMALLINT
Value range: [-32 768, 32 767]
INTEGER
Value range: [-2 147 483 648, 2 147 483 647]
REAL
Value range: –3.402823466 × 10³⁸ to –1.175494351×10⁻³⁸ and 1.175494351 × 10⁻³⁸ to 3.402823466 × 10³⁸
DOUBLE
Value range: –1.7976931348623158 × 10³⁰⁸ to –2.2250738585072014 × 10⁻³⁰⁸ and 2.2250738585072014 × 10⁻³⁰⁸ to 1.7976931348623158 × 10³⁰⁸
DECIMAL(p,s)
The position of the decimal point is determined by the precision and scale of the number.
The scale (number of digits to the right of the decimal point) cannot be negative and cannot be greater than the precision. The maximum precision is 31 digits.
NUMERIC(p,s)
DECFLOAT(n)
The value of n can only be 16 or 34.
When the value is 16, the value range is 10⁻³⁸³ to 10⁺³⁸⁴.
When the value is 34, the value range is 10⁻⁶¹⁴³ to 10⁺⁶¹⁴⁴.
CDM cannot migrate signaling NaN (sNaN) values. During migration, sNaN values are converted to quiet NaN values by default.
String
CHAR(n)
VARCHAR(n)
Range: char(length). A variable-length string of 1 to 65,535 characters.
LONG VARCHAR
Variable-length string, with a maximum of 32,700 characters
CLOB(n)
Character large object, with a maximum size of 2 GB
Date and time
DATE
0001-01-01 to 9999-12-31
TIME
00:00:00 to 23:59:59
TIMESTAMP(p)
0001-01-01-00.00.00.000000000000 to 9999-12-31-23.59.59.999999999999. p indicates the fractional second precision and ranges from 0 to 12.
BOOLEAN
TRUE, FALSE, or NULL
