Introduction to Incremental Packages
DataArts Studio provides and is billed based on basic and incremental packages. If the basic package cannot meet your demands, you need to buy an incremental package.
DataArts Studio Incremental Packages
Table 1 lists the incremental packages provided by DataArts Studio.
| Package Type | Description | Scenario | Purchase Mode |
| DataArts Migration Incremental Package (DataArts Migration – CDM Jobs and DataArts Migration – Offline Jobs) | A DataArts Migration (that is, CDM) incremental package provides resources for a CDM cluster.
CDM clusters can be used in the following scenarios:
| The DataArts Studio instance contains a CDM cluster that can be used for informal scenarios such as testing and trial use.
NOTE: Due to specifications restrictions, the free CDM cluster provided by a DataArts Studio instances can only be used for informal scenarios such as testing and trial use. To run your migration workloads, buy a CDM incremental package. In addition, you are not advised to use a CDM cluster that serves as a data connection agent to run data migration jobs. |
| DataArts Migration Resource Group Incremental Package (DataArts Migration – Real-Time Jobs) | This type of incremental package provides resource groups for real-time jobs in DataArts Migration. DataArts Migration resource groups can be used to migrate data to the cloud and ingest data into and export data out of a data lake. It provides wizard-based configuration and management and can integrate all, incremental, and real-time data from a single table, entire database, or database or table shard.
DataArts Migration resource groups can be used in the following scenarios: Data migration jobs can be created and run in CDM clusters to migrate data to the cloud or import data to the data lake. | By default, a DataArts Studio instance does not contain DataArts Migration resource groups. If you want to migrate data offline or in real time, create a DataArts Migration resource group incremental package. |
| DataArts DataService Exclusive Cluster Incremental Package (DataArts DataService Exclusive) | This package corresponds to a DataArts DataService Exclusive cluster. After you buy a DataArts DataService incremental package, the system automatically creates a cluster based on your selected specifications. DataArts DataService is a standard data service platform that allows you to generate data APIs quickly from data tables. Using the APIs, you can open your data in a simple, fast, low-cost, and secure way. To use DataArts DataService, you must buy a DataArts DataService Exclusive cluster first. | A DataArts Studio instance does not contain a DataArts DataService Exclusive cluster. To use DataArts DataService, you must buy a DataArts DataService Exclusive cluster incremental package. | Yearly/Monthly |
| Incremental Package for Job Node Scheduling Times/Day (Jobs in DataArts Factory, DataArts Quality, and DataArts Catalog) | This package is used to increase the quota of job node scheduling times/day. The quota of job node scheduling times/day varies depending on the DataArts Studio instance version. This quota refers to the total number of scheduling times of data development jobs, quality jobs, comparison jobs, scenarios, and metadata collection jobs per day. The number of scheduling times of data development job per day is measured by node (including the Dummy node), covering PatchData tasks but not test or retry upon failures. You can locate a DataArts Studio instance, click More, and select Quota Usage to view this quota. NOTE: The maximum number of concurrent data development job nodes of a DataArts Studio instance is related to the job node scheduling times/day quota of the instance.
| If the number of job node scheduling times per day is close to or has reached the upper limit, or if you want to increase the maximum number of concurrent nodes, you are advised to purchase a job node scheduling times/day incremental package. NOTE: If the total number of used scheduling times, scheduling times in use, and scheduling times to be used for job nodes on the current day exceeds the upper limit of this version, a message is displayed indicating that the number of job node scheduling times/day exceeds the quota when a batch processing job is scheduled or a real-time job is started. | Yearly/Monthly |
| Incremental Package for Technical Asset Quantity (Technical Assets in DataArts Catalog) | This package is used to increase the quota of the technical asset quantity. The maximum number of technical assets varies depending on the DataArts Studio instance version. This quota is calculated based on the total number of tables and OBS files in DataArts Catalog. You can locate a DataArts Studio instance, click More, and select Quota Usage to view this quota. | If the number of your technical assets is close to or has reached the upper limit, you are advised to purchase a technical asset quantity incremental package. | Yearly/Monthly |
| Incremental Package for Data Model Quantity (Models in DataArts Architecture) | This package is used to increase the quota of the data model quantity. The maximum number of data models varies depending on the DataArts Studio instance version. This quota is calculated based on the total number of logical models, physical models, dimension tables, fact tables, and summary tables in DataArts Architecture. You can locate a DataArts Studio instance, click More, and select Quota Usage to view this quota. | If the number of your data models is close to or has reached the upper limit, you are advised to purchase a data model quantity incremental package. | Yearly/Monthly |
