Updated on 2025-11-18 GMT+08:00
CDM Metrics
Function
Cloud Eye monitors the running status of cloud services and usage of each metric, and creates alarm rules for monitoring metrics.
After you create a CDM cluster, Cloud Eye automatically associates with CDM monitoring metrics to help you understand the running status of the CDM cluster.
  • This section describes the CDM metrics that can be monitored by Cloud Eye as well as their namespaces and dimensions.
  • For details about CDM monitoring metrics, see Querying CDM Metrics.
  • For details about how to set alarm rules, see Configuring CDM Alarm Rules.
You have obtained required Cloud Eye permissions.
Namespace
SYS.CDM
Metrics
Table 1 lists the CDM metrics.
Table 1 CDM metrics
ID
Name
Value Range
Unit
Conversion Rule
Dimension
Monitoring Period (Raw Data)
bytes_in
Bytes In
Measures the network inbound rate of the monitored object.
≥ 0 bytes/s
bytes/s
1024(IEC)
instance_id
1 minute
bytes_out
Bytes Out
Measures the network outbound rate of the monitored object.
≥ 0 bytes/s
bytes/s
1024(IEC)
instance_id
1 minute
cpu_usage
CPU Usage
Measures the CPU usage of the monitored object.
0% to 100%
N/A
instance_id
1 minute
mem_usage
Memory Usage
Measures the memory usage of the monitored object.
0% to 100%
N/A
instance_id
1 minute
pg_pending_job
Number of Queued Jobs
Number of jobs in the PENDING state in the CDM instance.
This metric is available in version 2.10.0.300 and later versions.
>=0
Count
N/A
instance_id
1 minute
pending_threads
Maximum Concurrent Extractors
Number of concurrent extraction threads in the Waiting state in the CDM instance.
>=0
Count
N/A
instance_id
1 minute
disk_usage
Disk Usage
Measures the disk usage of the physical server accommodating the monitored ECS, which is not accurate as that obtained on the monitored ECS.
0.001% to 90%
N/A
instance_id
1 minute
disk_io
Disk I/O
Measures the bytes read from and written to a disk per second on the physical server accommodating the monitored ECS, which is not accurate as those obtained on the monitored ECS.
≥ 0 byte/s
byte/s
1024(IEC)
instance_id
1 minute
tomcat_heap_usage
Heap Memory Usage
Measures the heap memory usage of the physical server accommodating the monitored ECS, which is not accurate as that obtained on the monitored ECS.
0.001% to 90%
N/A
instance_id
1 minute
tomcat_connect
Tomcat Concurrent Connections
Measures the number of Tomcat concurrent connections on the physical server.
0 to 2,147,483,647
Count
N/A
instance_id
1 minute
tomcat_thread_count
Tomat Threads
Measures the number of Tomcat threads on the physical server.
0 to 2,147,483,647
Count
N/A
instance_id
1 minute
pg_connect
Database Connections
Measures the number of Postgres database connections on the physical server.
0 to 2,147,483,647
Count
N/A
instance_id
1 minute
pg_submission_row
Rows
Measures the number of rows in the submission table of the Postgres database on the physical server.
0 to 2,147,483,647
Count
N/A
instance_id
1 minute
pg_failed_job_rate
Job Failure Rate
Measures the job failure rate of the sqoop process on the physical server.
0.001% to 100%
N/A
instance_id
1 minute
inodes_usage
Inodes Usage
Measures the disk inodes usage of the physical server accommodating the monitored ECS, which is not accurate as that obtained on the monitored ECS.
0.001% to 100%
N/A
instance_id
1 minute
Dimension
Key
Value
instance_id
CDM instance
You can obtain the value by referring to Querying a Specified Instance in a Cluster.
