From DLI
If the source link of a job is a DLI link, configure the source job parameters based on Table 1.
The lifecycle of a DLI bucket is two days by default. If a job runs for more than 48 hours, some data may be lost.
Parameter |
Description |
Example Value |
Resource Queue |
Resource queue to which the destination table belongs The default queue of DLI cannot be used for migration jobs. You need to create a SQL queue in DLI. |
cdm |
Database Name |
Name of the database to which data will be written |
dli |
Table Name |
Name of the table to which data will be written |
car_detail |
Partition |
Partition information Data can be read from DLI non-partitioned tables, or jobs in a partition can run concurrently only when the following conditions are met:
