Managing CDM Job Configuration
On the Settings tab page, you can perform the following operations:
- Maximum Concurrent Extractors
- Scheduled Backup/Restoration
- Environment Variables of Job Parameters
- Cluster Overload Protection
Maximum number of concurrent extraction tasks in a cluster
This parameter is also available on the Cluster Configuration page. You can change its value either on this page or the Cluster Configuration page.
- When data migration jobs are submitted, CDM splits each job into multiple tasks based on the Concurrent Extractors parameter in the job configuration.
Jobs for different data sources may be split based on different dimensions. Some jobs may not be split based on the Concurrent Extractors parameter.
- CDM submits the tasks to the running pool in sequence. Tasks (defined by Maximum Concurrent Extractors) run concurrently. Excess tasks are queued.
By setting appropriate values for the Concurrent Extractors and Maximum Concurrent Extractors parameters, you can accelerate migration.
- You are advised to set Maximum Concurrent Extractors to twice the number of vCPUs. For details, see Table 1.
- Configure the number of concurrent extractors based on the following rules:
- When data is to be migrated to files, CDM does not support multiple concurrent tasks. In this case, set a single process to extract data.
- If each row of the table contains less than or equal to 1 MB data, data can be extracted concurrently. If each row contains more than 1 MB data, it is recommended that data be extracted in a single thread.
- Set Concurrent Extractors for a job based on Maximum Concurrent Extractors for the cluster. It is recommended that the value of Concurrent Extractors is less than that of Maximum Concurrent Extractors.
- If the migration source is Hive and JDBC is used to read data, CDM does not support multi-concurrency. In this case, set the number of concurrent extractors to 1.
- If the destination is DLI, you are advised to set the number of concurrent extractors to 1. Otherwise, data may fail to be written.
This function depends on the OBS service. Backup files cannot be automatically aged. You need to manually delete them on a regular basis.
- Prerequisites
An OBS link has been created. For details, see OBS Link Parameters.
- Scheduled backup
On the Job Management page, click Settings and configure Scheduled Backup and its related parameters.
Table 2 Scheduled backup parameters Parameter
Example Value
Scheduled Backup
Whether to enable automatic backup. This function is used to back up jobs but not links.
Enable
Backup Policy
- All jobs: CDM backs up all table/file migration jobs and entire DB migration jobs regardless of the job statuses. However, historical jobs are not backed up.
- All jobs by groups: You select one or more job groups to back up.
All jobs
Backup Cycle
Select the backup cycle.
- Day: The backup is performed daily at 00:00:00.
- Week: The backup is performed at 00:00:00 every Monday.
- Month: The backup is performed at 00:00:00 on the first day of each month.
Day
OBS Link for Writing Backups
Link used to back up jobs to OBS. Select a link you have created on the Links page.
obs_link
OBS Bucket
OBS bucket where backup files are stored
cdm
Backup Data Directory
Directory where backup files are stored
/cdm-bk/
- Restoring jobs
If automatic backup has been performed, the backup list is displayed on the Configuration Management tab page. The OBS buckets where the backup files reside, backup paths and backup time are displayed.
You can click Restore Backup in the Operation column of the backup list to restore the CDM jobs.
When creating a migration job on CDM, the parameter (such as the OBS bucket name or file path) that can be manually configured, a field in a parameter, or a character in a field can be configured as a global variable, so that you can change parameter values in batches, or batch replace certain characters after jobs are exported or imported.
The following describes how to batch replace the OBS bucket name in a migration job.
- On the Job Management page, click the Configuration Management tab and configure environment variables.
bucket_1=A bucket_2=B
Variable bucket_1 indicates bucket A, and variable bucket_2 indicates bucket B.
- On the page for creating a CDM migration job, migrate data from bucket A to bucket B.
Set the source bucket name to ${bucket_1} and destination bucket name to ${bucket_2}.
Figure 1 Setting the bucket names to environment variables
- If you want to migrate data from bucket C to bucket D, you do not need to change the job parameters. You only need to change the environment variables on the Configuration Management tab page as follows:
bucket_1=C bucket_2=D
When cluster overload protection is enabled and the number of jobs exceeds the quota, no more jobs can be created or imported. This reduces the cluster overload risk. When jobs are created concurrently, the actual number of jobs may slightly exceed the quota. This has little impact on cluster stability. The job quota varies depending on the cluster specifications. For details, see Table 3 Relationship between the job quota and cluster specifications.
