From OpenTSDB
If the source link of a job is a CloudTable OpenTSDB link, configure the source job parameters based on Table 1.
| Parameter | Description | Example Value |
| Start Time | Query start time, which is a string or timestamp in yyyyMMddHHmmss format. | 20180920145505 |
| End Time | (Optional) Query end time, which is a string or timestamp in yyyyMMddHHmmss format. | 20180921145505 |
| Metric | Metric of the data to be migrated. You can specify a metric or select an existing metric in OpenTSDB. | city.temp |
| Aggregate Function | Aggregate function | sum |
| Tag | (Optional) If you specify a tag, only the tagged data will be migrated. | tagk1:tagv1,tagk2:tagv2 |
