Help Center/
DataArts Studio/
User Guide/
Buying and Configuring a DataArts Studio Instance/
Creating and Configuring a Workspace in Simple Mode/
Setting Workspace Quotas
Updated on 2025-09-09 GMT+08:00
Before using DataArts Studio, you need to set quotas for the current workspace. Currently, only the API quota of DataArts DataService Exclusive can be set. If the used quota of the current workspace exceeds the allocated quota or the total used quota exceeds the total allocated quota, some functions will be unavailable. For example, you cannot create APIs in DataArts DataService Exclusive.
- Used quota: quota that has been used in the current workspace. It is automatically calculated by the system.
- Allocated quota: quota allocated to the current workspace by the administrator
- Total used quota: quota that has been used in the current instance. It is automatically calculated by the system.
- Total allocated quota: quota that has been allocated to all workspaces in the current instance. It is automatically calculated by the system.
- Total quota: quota of the current instance. It is a fixed value and cannot be changed.
You are using either of the following accounts:
- DAYU Administrator or Tenant Administrator
- DAYU User, which is the administrator of the current workspace
- Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
- On the Workspaces page, locate a workspace and click Edit in the Operation column.
Figure 1 Workspace Information dialog box
- Locate API Quota of DataArts DataService Exclusive and click Edit in the Operation column to set it. Click OK to save the change.
The allocated quota indicates the quota that can be used in the current workspace. It cannot be less than the used quota or greater than the unallocated quota (total quota minus total allocated quota).
You can create 10 DataArts DataService Exclusive APIs for free in each DataArts Studio instance, and you will be charged for each extra API.
Figure 2 Setting the allocated quota
- In the Workspace Information dialog box, click OK.
Parent topic: Creating and Configuring a Workspace in Simple Mode
