Help Center/ DataArts Studio/ User Guide/ Buying and Configuring a DataArts Studio Instance/ Accessing the DataArts Studio Instance Console
Updated on 2025-07-25 GMT+08:00
You have obtained a DataArts Studio instance. For details, see Buying a DataArts Studio Instance.
- Log in to the Huawei Cloud console. Choose DataArts Studio from the service list in the upper left corner.
- If there are no DataArts Studio instances in the current region, the page on which you can buy an instance is displayed by default.
- If there is only one DataArts Studio instance in the current region, the DataArts Studio console homepage is displayed by default. Figure 1 Homepage of the console
- If there are multiple DataArts Studio instances in the current region, the instance list is displayed by default. Locate an instance and click Access to access the DataArts Studio console homepage. Figure 2 Instance list
Parent topic: Buying and Configuring a DataArts Studio Instance
