Updated on 2025-05-20 GMT+08:00
Connecting to a ClickHouse Data Source
DataArts Insight allows you to connect to a ClickHouse data source. This section describes how to connect DataArts Insight to a ClickHouse data source.
DataArts Insight can connect to ClickHouse through the following methods:
  • Public network connection: To connect to cloud service resources that do not belong to your current account, use this method. The data source must be bound to an EIP.
  • VPC network connection: To connect to cloud service resources under your current account, use this method.
  • VPCEP service: To connect to data sources that are not associated with your current account or for which you lack VPCEP permissions, as well as ECS self-built data sources, use this method.
Preparations
Before connecting to a data source, verify that a VPC endpoint security group or EIP is added. Check procedure:
  2. In the service list, choose Analytics > MapReduce Service to access the MRS console.
  3. Select a region in the upper left corner.
  4. In the navigation pane on the left, choose Clusters.
  5. Click the name of the cluster you want to connect to. The cluster overview page is displayed.
  6. Locate the Network Information area. Click Add Security Group Rule next to EIP. In the Add Security Group Rule dialog box, click Manage Security Group Rule. Click the Inbound Rules tab and check whether a VPC endpoint security group or EIP is added.
    • If yes, return to the DataArts Insight data source editing page to connect to the data source.
    • If no, perform the following steps to add a security group:
      1. Click Add Rule. In the displayed Add Inbound Rule dialog box, set the protocol, port, and source IP address. To add multiple rules, click Fast-Add Rule.
      2. Confirm the parameter settings and click OK to return to the DataArts Insight page and connect to the data source.
      If no EIP is bound, locate the Network Information area and click Bind next to EIP. Click Manage Security Group Rule and then the Inbound Rules tab to check or add a security group.
      If the data source connection test fails after the security group is added, the possible cause is that SASL_SSL is not enabled for that data source.
Accessing a ClickHouse Data Source Through a Public Network
  1. Log in to the DataArts Insight console.
  2. Click in the upper left corner of the management console to select a region and select an enterprise project from Enterprise Project in the upper right corner of the Workspace page.
  3. On the top menu of the console, click Project. On the displayed My Projects page, click the name of the desired project.
  4. In the navigation pane on the left, choose Data Management > Data Sources. On the displayed page, click Create Data Source. In the slide-out panel, set Source Database Type to ClickHouse and Access Network Type to Public network.
  5. Set other parameters based on Table 1.
    Figure 1 Parameters for connecting to a ClickHouse data source
    Table 1 Parameters
    Mandatory
    Yes
    Type of the accessed data source. In this example, ClickHouse is selected.
    Access Network Type
    Yes
    In this example, Public network is selected.
    Name
    Yes
    Name of the data source displayed in the list.
    Domain Name
    Yes
    IP address of the data source.
    Port
    Yes
    Port number for logging in to the database.
    Database
    Yes
    Name of the database to be logged in to.
    SASL_SSL
    It is used for trusted identity authentication and secure data transmission when DataArts Insight retrieves data from the data source. This function is enabled by default.
    To connect to an MRS security cluster, enable SASL_SSL. For an MRS non-security cluster, disable SASL_SSL.
    Username
    Yes
    Username for logging in to the database.
    Authentication Mode
    Yes
    The options are Password authentication and Certificate authentication.
    Password
    Yes
    Password for logging in to the database.
  6. Click Test Connection to test the data source connectivity.
  7. Once the test is successful, click OK.
Accessing a ClickHouse Data Source Through a VPC Network
  4. In the navigation pane on the left, choose Data Management > Data Sources. On the displayed page, click Create Data Source. In the slide-out panel, set Source Database Type to ClickHouse and Access Network Type to MRS ClickHouse.
  5. Set other parameters based on Table 2.
    • The selection of MRS instances only determines the VPC and subnet to be connected, and does not have any corresponding relationship with the server list.
    • Only the ClickHouse built in MRS is supported.
    Figure 2 Parameters for connecting to a ClickHouse data source
    Table 2 Parameters
    Mandatory
    Yes
    Access Network Type
    Yes
    In this example, MRS ClickHouse is selected.
    Region
    Yes
    Region where the ClickHouse service host is located.
    Name
    Yes
    No
    Description of the data source.
    Instance
    Yes
    Role instance corresponding to the ClickHouse service.
    Servers
    Yes
    List of servers where ClickHouse is located.
    Database
    Yes
    SASL_SSL
    Username
    Yes
    Authentication Mode
    Yes
    Password
    Yes
Connecting to a ClickHouse Data Source Through a VPC Endpoint Service
VPCEP enables connections to data sources using the VPCEP service name, offering flexible data access and addressing issues related to cross-account access and self-built data source access for ECS. Furthermore, the same main account and its IAM users can share a single connection channel, streamlining connection management. The existing access method eliminates the need for permission delegation, further simplifying operations.
  • Prerequisites
  • Procedure
    4. In the navigation pane on the left, choose Data Management > Data Sources. On the displayed page, click Create Data Source. In the slide-out panel, set Source Database Type to ClickHouse and Access Network Type to VPC Endpoint Service.
    5. Set other parameters based on Table 3.
      Table 3 Parameters
      Mandatory
      Yes
      Access Network Type
      Yes
      Select VPC Endpoint Service.
      Region
      Yes
      Name
      Yes
      Name of the data source displayed in the list, which is user-defined.
      No
      Yes
      Name of the VPCEP service to be connected. The prerequisites for connecting to a VPCEP service are as follows:
      Verify
      After entering the VPCEP service name, click Verify. If a green tick is displayed next to the VPC endpoint ID, the verification is successful. If a red exclamation mark () is displayed next to the VPC endpoint ID, the VPCEP service is connected to for the first time. In this case, you need to authorize the VPCEP service. To do so, log in to the VPCEP console. Under Network Console, choose VPC Endpoint > VPC Endpoint Services. On the displayed page, click the desired VPCEP service and click the Connection Management tab. On the tab page, authorize the VPCEP service. For details, see Managing Connections of a VPC Endpoint Service. Once the authorization is successful, click Verify again. The verification is successful.
      • All initial connections to the VPCEP service from different data sources require approval.
      • Only an administrator account or an account with administrator permissions can approve the connection. If your current account does not have approval permissions, contact an administrator account for approval.
      VPC Endpoint ID
      Yes
      This parameter is automatically filled in once you entered the VPCEP name and clicked Verify.
      Port
      Yes
      Database
      Yes
      Username
      Yes
      Authentication Mode
      Yes
      Password
      Yes
      SASL_SSL
