Updated on 2025-09-25 GMT+08:00
Auditing
Cloud Trace Service (CTS) provides records of operations performed on cloud service resources.
With CTS, you can record operations associated with CTS itself for later query, audit, and backtracking.
Table 1 CTS operations (creation, modification, and deletion) that can be recorded by itself
Operation
Resource Type
Trace Name
Creating a tracker
tracker
createTracker
Modifying a tracker
tracker
updateTracker
Disabling a tracker
tracker
updateTracker
Enabling a tracker
tracker
updateTracker
Deleting a tracker
tracker
deleteTracker
Creating a key event notification
notification
createNotification
Deleting a key event notification
notification
deleteNotification
Modifying a key event notification
notification
updateNotification
Changing the status of a key event notification
notification
updateNotificationStatus
Disabling a key event notification
notification
updateNotification
Enabling a key event notification
notification
updateNotification
Modifying settings of the configuration center
configuration
updateConfiguration
Table 2 CTS operations (query) that can be recorded by itself
Operation
Resource Type
Trace Name
Querying the trace list
trace
listTraces
Exporting the trace list
trace
exportTrace
Querying one or more key event notifications
notification
listNotification
Querying one or more trackers
tracker
listTrackers
Querying the configuration center
configuration
showConfiguration
