Enabling Verification of Trace File Integrity
During a security investigation, operational records will not be able to serve as effective and authentic evidence if they are deleted or tampered with. You can enable the integrity verification on CTS to ensure the authenticity of trace files. CTS supports integrity verification of trace files for trackers configured with OBS transfer.
 - Click
 in the upper left corner to select the desired region and project. - Click
 in the upper left corner and choose Management & Governance > Cloud Trace Service. The CTS console is displayed. - Choose Tracker List in the navigation pane.
 - Click Configure in the row of the management tracker system. On the displayed Configure Tracker page, click Next, and enable Verify Trace File in the transfer configuration step.
