Trace Structure
A trace consists of multiple key fields shown in Table 1.
- This section describes the key trace fields displayed on the CTS console.
- When some fields are displayed on the CTS console, their formats are optimized for easy understanding.
Field | Mandatory | Type | Description |
time | Yes | Long | Timestamp when a trace was generated. The value is the local standard time, for example, 1660927593570. This field is transmitted and stored in the form of a timestamp. It is the total number of milliseconds from 00:00:00, January 1, 1970 to the current time. |
user | Yes | UserInfo object | Information of the user who performed the operation that triggered the trace. |
request | No | String | Request of an operation on resources. |
response | No | String | Response to a user request, that is, the returned information for an operation on resources. |
service_type | Yes | String | Type of a cloud service whose traces are to be queried. |
event_type | Yes | String | Trace type. |
project_id | Yes | String | ID of the project to which the trace belongs. |
resource_type | Yes | String | Type of the resource on which the operation was performed. |
resource_account_id | No | String | ID of the account to which the resource belongs. This parameter has a value only when resources are operated across tenants. For example, if tenant A operates resources of tenant B, the value is the account ID of account B. Note: In the cross-tenant scenario, CTS copies an audit log so that both tenants can view the trace on the CTS console. |
read_only | No | boolean | Whether a user request is read-only. |
tracker_name | No | String | Name of the tracker that records the trace.
operation_id | Yes | String | Operation ID of the trace. |
resource_name | No | String | Name of a resource on which the recorded operation was performed. |
resource_id | No | String | ID of a cloud resource on which the recorded operation was performed. |
source_ip | Yes | String | IP address of the tenant who performed the operation that triggered the trace. The value of this parameter is empty if the operation is triggered by the system. |
domain_id | Yes | String | ID of the account that triggers the trace. |
trace_name | Yes | String | Trace name. |
trace_rating | Yes | String | Trace status. The value can be normal, warning, or incident.
trace_type | Yes | String | Trace source. For management traces, the value can be ApiCall, ConsoleAction, or SystemAction. For data traces, the value can be ObsSDK or ObsAPI. |
api_version | No | String | Version of the API called in a trace. |
message | No | String | Remarks added by other cloud services to a trace. |
record_time | Yes | Number | Timestamp when a trace was recorded by CTS. |
trace_id | Yes | String | Trace ID. The value is the UUID generated by the system. |
code | No | String | HTTP status code returned by the associated API. |
request_id | No | String | Request ID. |
location_info | No | String | Additional information required for fault locating after a request error. |
endpoint | No | String | Endpoint in the detail page URL of the cloud resource on which a recorded operation was performed. |
resource_url | No | String | Detail page URL (excluding the endpoint) of the cloud resource on which a recorded operation was performed. |
enterprise_project_id | Yes | String | ID of the enterprise project to which the resource belongs. |
user_agent | No | String | ID of the request client agent. |
content_length | No | Number | Length of the request message body. |
total_time | No | Number | Request response time. |
type | No | String | Identity type of the operator. |
principal_id | No | String | Identity ID of the operator.
principal_urn | No | String | URN of the operator.
account_id | No | String | Account ID. To obtain it, hover over the username in the upper right corner of the console, select My Credentials from the drop-down menu, and locate the ID on the right of Account ID. |
access_key_id | No | String | Access key ID. |
id | Yes | String | User ID. To obtain it, hover over the username in the upper right corner of the console, select My Credentials from the drop-down menu, and locate the ID on the right of IAM User ID. |
name | Yes | String | Username. To obtain it, hover over the username in the upper right corner of the console, select My Credentials from the drop-down menu, and locate the name on the right of IAM Username. |
domain | Yes | BaseUser object | Domain information of the user who performed the operation generating the trace. |
user_name | No | String | Username. The meaning of user_name is the same as that of name. |
principal_is_root_user | No | String | Whether the operator is user root.
invoked_by | No | Array of strings | Name of the service that sends the request. The value is ["service.console"] for console operations. |
session_context | No | SessionContext object | Temporary security credential attribute. |
OriginUser | No | String | Information about the original user who initiates the assumed session. |
id | Yes | String | Account ID. To obtain it, hover over the username in the upper right corner of the console, select My Credentials from the drop-down menu, and locate the ID on the right of Account ID. |
name | Yes | String | Account name. To obtain it, hover over the username in the upper right corner of the console, select My Credentials from the drop-down menu, and locate the name on the right of Account Name. |
attributes | No | Attributes object | Temporary security credential attribute. |
