Deleting a Tracker
Deleting a data tracker on the CTS console is available, and does not affect the existing operation records. This section describes how to delete a data tracker on the console.
After a tracker is deleted, traces can still be reported to CTS. You can view traces of the last seven days in the trace list. However, new traces recorded after you disable the tracker cannot be viewed and transferred to OBS or LTS, and key event notifications will not be sent.
A data tracker has been created.
Deleting a Data Tracker
- Click
in the upper left corner to select the desired region and project. - Click
in the upper left corner and choose Management & Governance > Cloud Trace Service. The CTS console is displayed. - Choose Tracker List in the navigation pane.
- Click Delete in the Operation column of the target configuration item. Figure 1 Deleting a tracker
- Click OK.
