Accounts
You can log in to the engine console and create an account or manage a specified account created on the engine based on service requirements.
If the Nacos engine is upgraded from an earlier version to 2.1.0.1, the system has the built-in account nacos by default. The ROLE_ADMIN role is associated with the account and cannot be deleted. The default password of the built-in account is nacos. You are advised to reset the password.
Creating an Account
Create an account and associate a proper role with the account. Users who use the account have the access and operation permissions on the Nacos engine.
- Log in to CSE.
- In the left navigation pane, choose Registry/Configuration Center.
- Click the target Nacos engine.
- Choose Permission Control.
- Choose Accounts > Create Account and configure account parameters by referring to the following table:
Account
Enter an account name. The account name cannot be changed once the account is created.
Password
Enter a password.
Confirm Password
Enter the password again.
- Click OK.
Resetting a Password
For security purposes, you can reset your password on the console.
- Log in to CSE.
- On the Accounts tab page, click Reset Password in the Operation column of the target account.
- Enter and confirm a new password, select I Understand, and click Save.
Deleting an Account
- Log in to CSE.
- On the Accounts tab page, click Delete in the Operation column of the target account. In the displayed dialog box, enter DELETE and click OK.
