- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Before You Start
- Permissions Management
Exclusive ServiceComb Engine
- Creating a ServiceComb Engine
Managing ServiceComb Engines
- Viewing ServiceComb Engine Information
- Obtaining the Service Center Address of a ServiceComb Engine
- Obtaining the Configuration Center Address of a ServiceComb Engine
- Viewing the Instance Quota of a ServiceComb Engine
- Viewing the Configuration Item Quota of a ServiceComb Engine
- Configuring Backup and Restoration of a ServiceComb Engine
- Managing Public Network Access for a ServiceComb Engine
- Viewing ServiceComb Engine Operation Logs
- Upgrading a ServiceComb Engine Version
- Deleting a ServiceComb Engine
- Changing ServiceComb Engine Specifications
- Managing Security Authentication for a ServiceComb Engine
- Managing Tags
- Using ServiceComb Engines
- Registry/Configuration Center
- Key Operations Recorded by CTS
Best Practices
- CSE Best Practices
ServiceComb Engines
ServiceComb Engine Application Hosting
- Hosting Spring Cloud Applications Using Spring Cloud Huawei SDK
- Hosting a Java Chassis Application
- Registry/Configuration Centers
Developer Guide
- Overview
- Developing Microservice Applications
- Preparing the Environment
- Connecting Microservice Applications
- Deploying Microservice Applications
- Using ServiceComb Engine Functions
- Appendix
API Reference
- Before You Start
- API Overview
- Calling APIs
- Examples
CSE API
- API Calling
- Dynamic Configuration
Engine Management
- Querying Flavors Supported by a Microservice Engine
- Querying the Microservice Engine List
- Creating an Exclusive Microservice Engine
- Querying Details About a Microservice Engine
- Deleting a Microservice Engine
- Querying Details About a Microservice Engine Job
- Retrying an Exclusive ServiceComb Engine
- Upgrading an Exclusive ServiceComb Engine
- Changing Microservice Engine Specifications
- Updating the Configuration of an Exclusive Microservice Engine
Microservice Governance
- Querying the Governance Policy List
- Creating a Dark Launch Policy
- Querying a Dark Launch Rule of a Microservice
- Deleting a Dark Launch Policy
- Changing a Governance Policy
- Deleting a Governance Policy
- Querying Governance Policy Details
- Creating a Governance Policy
- Querying the Governance Policy List of a Specified Kind
- Nacos API
ServiceComb API
- API Calling
- Authentication
Microservice
- Querying Information About a Microservice
- Deleting Definition Information About a Microservice
- Querying Information About All Microservices
- Creating Static Information for a Microservice
- Deleting Static Information About Microservices in Batches
- Modifying Extended Attributes of a Microservice
- Querying the Unique Service or Schema ID of a Microservice
- Schema
Microservice Instance
- Registering a Microservice Instance
- Querying a Microservice Instance Based on service_id
- Deregistering a Microservice Instance
- Querying Details About a Microservice Instance
- Modifying the Extended Information About a Microservice Instance
- Modifying Status of a Microservice Instance
- Sending Heartbeat Information
- Querying a Microservice Instance by Filter Criteria
- Querying Microservice Instances in Batches
- Dependency
- Configuration Management
- Appendixes
- Change History
- SDK Reference
- Precautions When Using Huawei Cloud CSE
- Nacos Engines
ServiceComb Engines
- How Do I Perform Local Development and Testing?
- How Can I Handle a Certificate Loading Error?
- What If the Header Name Is Invalid?
- What Is the Performance Loss of Mesher?
- Why Is "Version validate failed" Displayed When I Attempt to Connect to the Service Center?
- Why Is "Not enough quota" Displayed When I Attempt to Connect to the Service Center?
- What Should I Do If the Service Registration Fails After IPv6 Is Enabled for the Exclusive ServiceComb Engine with Security Authentication Enabled?
- What Is Service Name Duplication Check?
- Why Do I Have to Define Service Contracts?
- Why Are Microservice Development Framework and Netty Versions Unmatched?
- What Do I Need to Know Before Upgrading an Exclusive ServiceComb Engine?
- What Must I Check Before Migrating Services from the Professional to the Exclusive Microservice Engine?
- Why Is "Duplicate cluster name" Displayed?
- Error Message "the subnet could not be found" Is Displayed When the Access Address Fails to Be Processed During Engine Creation
- Why Is Error "does not match rule: {Max: 100, Regexp: ^[a-zA-Z0-9]{1,160}$|^[a-zA-Z0-9][a-zA-Z0-9_\-.]{0,158}[a-zA-Z0-9]$}"}" Reported?
- What Should I Do If SpringCloud Applications Fail to Connect to the Configuration Center of ServiceComb Engine 2.x?
- Why Could My the Global Configuration Not Be Modified?
- Obtain Configurations Failed
- Videos
Service Management
You can use the CSE console to manage services registered with Nacos.
A Nacos engine instance has been created.
Creating a Service
You can create a service on the console. The newly created service is an empty service (that is, the number of providers is 0). By default, the empty service is displayed in the service list. If you do not want to display the empty service, click next to Hide Empty Service.
- Log in to CSE.
- In the left navigation pane, choose Registry/Configuration Center.
- Click the target Nacos instance.
- Choose Service Management.
- Select a namespace from the Namespace drop-down list. The ID is automatically filled in the Namespace ID box.
If the selected namespace is public, the namespace ID is empty by default.
- Click Create Service. In the displayed dialog box, set configuration items as follows. Configuration items marked with an asterisk (*) are mandatory.
Table 1 Parameters Parameter
*Service Name
Enter a service name. The value can contain a maximum of 236 characters, including digits, letters, and special characters "_-.:".
Group
Set the group to which the service belongs. The value can contain a maximum of 128 characters, including digits, letters, and special characters "_-.:".
*Protection Threshold
If the ratio of healthy instances to the total instances is less than the threshold, a protection threshold is triggered. The value ranges from 0 to 1. The default value is 0.
- Click OK.
Viewing the Service List
- Log in to CSE.
- Choose Service Management. Select a namespace from the Namespace drop-down list. The ID is automatically filled in the Namespace ID box.
- View all services in the namespace of the engine.
You can search for the target service by service name or group name.
Target service fuzzy search supports characters: ,$*+.|?
Viewing Service Details
- Log in to CSE.
- Click the target service to view its details.
- View basic service information, including the service name, namespace name, service group, namespace ID, protection threshold, and number of clusters.
- The Instances tab displays the instance information, including the IP address, port number, cluster, health status, online/offline status, weight, and metadata. You can also perform Instance Operations, such as searching for instances based on metadata, bringing instances online/offline, and modifying weights.
- The Subscribers tab displays the list of all client instances that subscribe to the current service. Versions of subscribers and clients are displayed in the list.
Instance Operations
- Search by metadata: On the Instances tab, select a cluster from Clusters, enter the metadata key and value in Search Metadata, and click Filter to display the instances that meet the search criteria. Click Clear to clear the search data.
- Bring an instance online or offline: On the Instances tab, click Online or Offline in the Operation column of the target instance. The instance status will be updated accordingly.
- Modify instance weight: On the Instances tab, move the cursor to the Weight column of the target instance, click
to modify the weight (ranging from 1 to 99), and click OK.
To use the Nacos weight function for traffic load balancing, register NacosRule provided by Nacos as a bean on the client.@Bean NacosRule nacosRule() { return new NacosRule(); }
Add the following configuration item to the application.properties configuration file:xxx-service.ribbon.NFLoadBalancerRuleClassName=com.alibaba.cloud.nacos.ribbon.NacosRule
xxx-service indicates the service name of the client, that is,spring.application.name=xxx-service
Deleting a Service
- Only empty services can be deleted. If the number of instance is not 0, the services cannot be deleted.
- If a service remains empty for more than 1 minute, the Nacos automatically deletes the service.
- Log in to CSE.
- In the left navigation pane, choose Service Management and click Delete in the Operation column of the target service.
