On this page
Help Center/ Cloud Server Backup Service/ User Guide/ Backup/ Using Backups to Create Images
CSBS allows you to create images using ECS backups. You can use the images to provision ECSs for fast restoring the service running environment.
  • The following operations have been performed before you use an ECS's backup to create an image:
  • The backup you want to use to create an image meets either of the following two conditions:
    • The backup is in the Available state.
    • The backup is in the Creating state which is marked with Image can be created.
    Once a backup creation starts, the backup enters the Creating state. After a while, a message stating "Image can be created" is displayed under Creating. In this case, the backup can be used for creating an image, even though it is still being created and cannot be used for restoration.
  • The backup you want to use to create an image contains the system disk data.
  • Images created from a backup are the same, so CSBS allows you to use a backup to create only one full-ECS image that contains the whole data of the ECS's system disk and data disks, in order to save the image quota. After an image is created, you can use the image to provision multiple ECSs in a batch.
  • A backup with an image created cannot be deleted manually or automatically. If you want to delete such a backup, delete its image first. If a backup is automatically generated based on a backup policy and the backup has been used to create an image, the backup will not be counted as a retained backup and will not be deleted automatically.
  1. Log in to the CSBS management console.
    2. Under Storage > Cloud Server Backup Service.
  2. Click the Backups tab and locate the desired server backup. For details, see Viewing a Backup.
  3. In the row of the backup, click Create Image.
  4. Create an image by referring to Creating a Full-ECS Image Using a CSBS Backup.
  5. If you want to use an image to provision ECSs, see Creating ECSs Using an Image.
