Help Center/ Cloud Phone Host/ User Guide/ Using AOSP/ Dynamically Changing the System Language
Updated on 2025-04-24 GMT+08:00
Function
Run the am command to dynamically change the system language.
How to Use
adb shell am update-config --locale Language tags
  • Language label of each country
    For details, see Language Tags. For the source code of the opn-source project, see /aosp/frameworks/base/core/res/res/values/locale_config.xml.
  • Use commas (,) to separate multiple language tags.
    For example, to change the current language list to English+Chinese and configure English to the default language, run the following command:
    adb shell am update-config --locale zh-CN,en-US
  • The setting takes effect immediately.
