Simulating Location Information
Function
The simulated positioning information of CPH includes GPS data, base station information, and Wi-Fi Basic Service Set Identifier (BSSID). CPH also provides the geocoding and reverse geocoding.
How to Use
- Injection of GPS data and base station information
Use the adb shell of the cloud phone and run the echo "parameters" > /data/gps/fifo command. Parameters are separated by colons.
echo "longitude=113.370592:latitude=23.123642:cell_type=GSM:mcc=460:mnc=2:lac=37107:cid=263496967" > /data/gps/fifo
- Continuous GPS data injection (Non-blocking injection is recommended.)
Use self-developed or third-party SDK application code to continuously inject GPS data in O_NONBLOCK (non-blocking) mode.
Example:
#define GPSFifoName "/data/gps/fifo" if((fifo_fd = open(GPSFifoName, O_WRONLY | O_NONBLOCK)) < 0) { ALOGE("open fifo "%s" (write) fail, error = %s\n", GPSFifoName, strerror(errno)); return; } //Note: Use colons (:) to separate cmd parameters. char* cmd = "longitude=113.370592:latitude=23.123642:cell_type=GSM:mcc=460:mnc=2:lac= 37107:cid=263496967"; len = strlen(cmd); if(write(fifo_fd, cmd, len) != len) { ALOGE("%s: write "%s" to "%s" fail: %s", FUNCTION, cmd, GPSFifoName, strerror(errno)); }
- Wi-Fi BSSID simulation
Set com.cph.wifi.bssid attribute to simulate which Wi-Fi a cloud phone is connected to.
Example:
setprop com.cph.wifi.bssid 02:00:00:00:00:00
- Parameters related to GPS data and base station information
Table 1 GPS data Parameter
Mandatory
Default Value
latitude
Specifies the latitude.
The north latitude is positive and the south latitude is negative.
Yes
22.657501
Value range: –90.000000 to 90.000000
Unit: Degree (°)
longitude
Specifies the longitude
The east longitude is positive and the west longitude is negative.
Yes
114.055939
Value range: –180.000000 to 180.000000
Unit: Degree (°)
altitude
Specifies the altitude.
No
51.0
Unit: Meter
speed
Specifies the speed.
No
0.0
Unit: Meter
bearing
Specifies the azimuth.
0° indicates due north, 90° indicates due east, 180° indicates due south, and 270° indicates due west.
No
30.0
Value range: 0.0 to 360.0
Unit: Degree (°)
accuracy
Specifies the positioning accuracy.
No
90.0
Unit: Meter
Table 2 Base station information Parameter
Mandatory
cell_type
Specifies the base station type.
Yes
The type can GSM, CDMA, WCDMA, or LTE.
mcc
Specifies the country code.
No
Example: 460
mnc
Specifies the mobile network code of a base station.
No
For Code-division multiple access (CDMA), only system id is available. mnc is used for injection.
lac
Specifies the area code of a base station.
Yes
For CDMA, only network id is available. lac is used for injection.
For Long Term Evolution (LTE), only tac is available. lac is used for injection.
cid
Specifies the base station ID.
Yes
For CDMA, only base station id is available. cid is used for injection.
For LTE, only ci is available. cid is used for injection.
- All characters are English characters.
- The World Geodetic System 1984 (WGS84) is used for GPS data.
- Both LocationManager GPS_PROVIDER and NETWORK_PROVIDER use the longitude and latitude information of the GPS.
- Geocoder that supports geocoding and reverse geocoding is supported only in the Chinese Mainland, Hong Kong, and Macao.
- The setting takes effect immediately.
