Disabling the Notification System
Disabling Notifications from All Applications
Function
The notification system (including the message notification and toast displayed on the top of the screen) will be disabled. The notifications of all applications will be disabled.
How to Use
Call the Updating Properties of Cloud Phones API and set ro.com.cph.notification_disable to 1. As a result, the notification system will be disabled. To enable Toast only, set ro.com.cph.toast_enable to 1.
- For attribute ro.com.cph.notification_disable, value 0 indicates that the notification is allowed, and value 1 indicates that the notification is not allowed.
- For attribute ro.com.cph.toast_enable, value 0 indicates that toast is disabled, and value 1 indicates that toast is enabled.
- The setting takes effect immediately.
Disabling Notifications from Specified Applications
Function
Notification blacklist can be applied. Applications in the blacklist will be forbidden to send notifications.
How to Use
Push the configuration file to the /data/local/config/NotificationAPP path.
