Updated on 2025-10-29 GMT+08:00
Startup Script
Function
You can customize the startup script.
How to Use
Push your own script file to the /data/local/tmp/extend_custom.sh path.
- The script file path must be /data/local/tmp/extend_custom.sh.
- The owner group of the file must be root:root and the file permission must be 750 (rwxr-x---). If the permission is incorrect, the script cannot be executed.
- The setting takes effect upon restart.
- The timeout duration for script execution is 10s.
Parent topic: Using AOSP
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
