Key Cloud Phone Operations Recorded by CTS
Cloud Trace Service (CTS) is a log audit service for Huawei Cloud security. It allows you to collect, store, and query cloud resource operation records. You can use these records to perform security analysis, audit compliance, track resource changes, and locate faults.
With CTS, you can record operations associated with CPH for later query, audit, and backtrack operations.
Enable CTS before using it. If CTS is not enabled, resource operations cannot be recorded. After CTS is enabled, CTS automatically creates a tracker and records all operations of the current tenant in the tracker. CTS traces of the last seven days can be displayed at most. To save operation records for a long time, you can store trace files in OBS buckets. For details, see Overview.
| Operation | Resource | Trace Name |
| Buying a cloud phone | phone | createCloudPhone |
| Updating the cloud phone name | phone | updatePhoneName |
| Resetting a cloud phone | phone | resetCloudPhone |
| Restarting a cloud phone | phone | restartCloudPhone |
| Adding SD card files | phone | addSdFiles |
| Deleting SD card files | phone | deleteSdFiles |
| Setting event notification | phone | setEventNotification |
