Associating Cloud Repositories
If you have stored project files on the local computer, you need to initialize the local project files as a Git repository and associate them with a cloud repository provided by CodeHub before using CodeHub.
You have installed the Git client and bound the SSH key of the Git client to CodeHub.
- Create a remote repository.
If you select gitignore based on your local code library, some non-development files will be ignored and will not be managed in Git.
- Initialize the local repository to a Git repository.
Open the Git Bash client in your repository and run the following command:
git init
The following figure shows that the initialization is successful. The current folder is the local Git repository.
- Bind the local repository to the cloud repository.
- Go to the cloud repository and obtain the repository address.
- Run the remote command to bind the local repository to the cloud repository:
git remote add <repository_alias> <repository_address>
Example:
git remote add origin git@*****/java-remote.git # Change the address to that of your repository.
By default, origin is used as the repository alias when you clone a remote repository to the local computer. You can change the alias.
If the system displays a message indicating that the repository alias already exists, use another one.
If no command output is displayed, the binding is successful.
- Pull the master branch of the cloud repository to the local repository.
This step is performed to avoid conflicts.
git fetch origin master # Change origin to your repository alias.
- Commit local code files to the master branch.
Run the following commands:
git add .
git commit -m "<your_commit_message>"
The following figure shows a successful execution.
- Bind the local master branch to the cloud master branch.
git branch --set-upstream-to=origin/master master # Change origin to your repository alias.
If the following information is displayed, the binding is successful.
- Merge the files in the cloud repository and local repository and store them locally.
git pull --rebase origin master # Change origin to your repository alias.
The following figure is displayed, indicating that the merged repository has been placed in the working directory and repository.
- Push the local repository to overwrite the cloud repository.
Run the push command directly because the repositories have been bound:
git push
After the operation is successful, pull the repository to verify that the version of the cloud repository is the same as that of the local repository.
