Custom Templates
Build template selection: If the preset build templates cannot meet your build requirements, you can customize a build template.
- Log in to the CodeArts Build homepage.
- Select a build task from the list and click the task name. The Build History page is displayed.
- Click
in the upper right corner. Select Make Template from the drop-down list.
A build task that uses any private parameters cannot be saved as a template. For details about how to set build parameters, see Configuring Parameters.
- Enter the template name and description, and click Save.
- Click the username in the upper right corner, and select from the drop-down list.
- In the navigation pane, choose . The saved template is displayed in the list.
You can perform the following operations on saved templates.
Table 1 Managing custom templates Operation
Favorite a template
Click
to add the template to your favorites.Delete a template
Click
. In the displayed dialog box, click Yes to delete the template.
