Building with sbt
Build a Scala or Java project with sbt.
Build on GUI
Add Build with sbt, when configuring build actions. Set the parameters according to Table 1.
| Parameter | Description |
| Action Name | Assign a custom name to the build action. The name can contain:
| Tool Version | Only the default version sbt1.3.2-jdk1.8 is supported currently. |
| Commands | Configure the sbt commands, or use the default ones. If you have special build requirements, enter your custom build script in the text box. For more commands, see the sbt official website. |
| Continue After Failure | Specify whether to proceed after the current action fails by setting the parameter to either Yes or No. |
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
1 2 3 4 5 6 7 8 | version: 2.0 # The value must be 2.0. steps: BUILD: - sbt: inputs: command: | sbt package ignore_fail: true |
| Parameter | Type | Description |
| command | String | Configure the sbt commands. For more commands, see the sbt official website. |
| ignore_fail | String | Whether to proceed after the current action fails.
