Help Center/ CodeArts Build/ User Guide/ Configuring a Build Task/ Configuring Build Actions/ Uploading a Software Package to Release Repos
Updated on 2026-10-23 GMT+08:00
For details about the restrictions on uploading software packages, see constraints of CodeArts Artifact.
  • Only files can be uploaded, folders cannot be uploaded, and directories cannot be automatically created.
    For example, the a directory contains the aa file and b directory that contains the bb file, and the build package directory is set to a/**.
    When the a directory is scanned, both aa and bb will be uploaded to the same directory, and the system will not create a b directory in release repos.
  • To upload a folder, package it before adding the Upload to Release Repo action. You can package the folder by running the packaging command or adding the Run Shell Commands action.
  • To view the iteration version of the software package, run the commands provided in Running Shell Commands along with the following command before proceeding with the operations in this section. In the following command, build_version=11cc is a custom parameter.
    echo "build_version=11cc" >> ${WORKSPACE}/.ci_build_mete
Tutorial Video
This video shows how to build with Maven and upload the resulting software package to the release repo using the GUI.
Build on GUI
Add Upload to Release Repo, when configuring build actions. Set the parameters according to Table 1.
When you select Windows executors, add action Upload Software Package to Release Repos (Windows).
Table 1 Parameters for uploading a software package to the release repo
Action Name
Assign a custom name to the build action. The name can contain:
  • Letters, digits, hyphens (-), underscores (_), commas (,), semicolons (;), colons (:), periods (.), slashes (/), and parentheses.
  • 1 to 128 characters.
Package Location
Directory for storing the build result.
  • The build package directory supports regular expression matching. ** means that the system recursively traverses the current directory. * indicates zero or multiple characters. ? indicates one character.
  • The system file uses slashes (/) as separators, and the path is not case-sensitive.
Examples:
  • *.class: Matches files whose names end with .class in the current directory.
  • **/*.class: Recursively matches all files whose names end with .class in the current directory.
  • test/a??.java: Matches Java files whose names start with a followed by two characters in the test directory.
  • **/test/**/XYZ*: Recursively matches all files whose parent directory is test and whose names start with XYZ, for example, abc/test/def/ghi/XYZ123.
Version
Optional.
Set the name of the directory where the software package generated by the build task will be uploaded to the release repo.
  • Not specified (recommended): Use the build number to name the directory for storing files uploaded to release repos.
  • Specified: Files in the directory with the same name may be overwritten.
Package Name
Optional.
Set the name for the software package generated by the build task. The name will be used when the package is uploaded to the release repo.
  • Not specified (recommended): Use the original file name to name the file uploaded to release repos. Leave Package Name unspecified so that all files matching the build package directory can be uploaded.
  • Specified: A file may be overwritten when another file with the same name is uploaded. For multiple file uploads with different package names, repeat the upload action for each file.
Custom Directory
Optional.
After you specify the custom upload directory, the uploaded software package is uploaded to the custom upload directory/version number/Software package name directory.
Continue After Failure
Specify whether to proceed after the current action fails by setting the parameter to either Yes or No.
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
 3
 4
 5
 6
 7
 8
 9
10
11
version: 2.0 # The value must be 2.0.
steps:
  BUILD:
    - upload_artifact:
           inputs:
             path: "**/target/*.?ar"
             version: 2.1
             custom_upload_path: /phoenix-sample-ci/
             upload_tool: curl
             ignore_fail: true
Table 2 Parameters in the sample code
Type
path
String
Examples:
version
String
Optional.
Enter the release version number.
name
String
Optional.
Enter the name of the package generated during the build.
custom_upload_path
String
Optional.
upload_tool
String
Use the curl client to upload the software package.
ignore_fail
String
Specify whether to proceed after the current action fails.
  • true: Yes
  • Empty: No
How Release Versions and Package Names Impact Uploads
Figure 1 Impact of an unspecified release version and package name on uploads
