Help Center/CodeArts Check/User Guide/Configuring Project-level Role Permissions
Updated on 2025-07-31 GMT+08:00
Assign a role to the new member. Each role comes with its own default permissions. For details, see Table 1.
Table 1 Default role permissions in CodeArts Check
Permission/Role
Project Administrator
Project Manager
Developer
Test Manager
Tester
Participant
Viewer
Product Manager
System Engineer
Committer
Tasks
Create
Execute
View
Edit
Delete
Rule sets
Set as default
Issues
View
Edit
Accessing CodeArts Check
  1. Log in to the Huawei Cloud console.
  2. Click in the upper left corner and choose Developer Services > CodeArts Check from the service list.
  3. You can access CodeArts Check in either of the following ways:
    • From the service portal
      Click Access Service. This page displays the check task list of the current user.
    • From the project list
      1. Click Access Service.
      2. On the navigation bar, click Homepage.
      3. Click the name of the project to be viewed.
      4. Choose Code > Check.
    Click in the upper left corner of the page and select a region.
  1. Access CodeArts Check through a project.
  2. In the navigation pane, choose Settings > Permissions.
  3. On the displayed page, configure permissions for different roles in CodeArts Check.
