Updated on 2025-09-23 GMT+08:00
Managing Files
CodeArts Repo allows you to edit and compare files, and trace file changes.
When you access the repository details console, you will be on the Files subtab of the Code tab page. You can switch to different branches and tags to view the files in the corresponding version. As shown in the following figure, the file list under the main branch is displayed on the left, the repository name (file details of a branch or tag version) and history (branch or tag version) tab pages are displayed on the right.
Managing the File List
The file list is on the left of the Files tab page of the repository. The file list provides the following functions:
  1. Click a branch name to switch the branch and tag. After the branch and tag are switched, the file directory of the corresponding version is displayed.
  2. Click to display the search box. You can search for files in the file list.
  3. You can click to perform the following extended functions. You can also move the cursor to the folder name and click to perform the following operations in the folder.
    • Creating a file
      Creating a file on the CodeArts Repo console is to create a file and run the add, commit, and push commands. A commit record is generated.
      On the Create File page, enter the file name, select the target template type, select the encoding type, enter the file content and commit information, and click OK. The Commit Message field is equivalent to the -m message in git commit and can be used to view associated work items.
    • Creating a directory
      Creating a directory on the CodeArts Repo console is to create a folder structure and run the add, commit, and push commands. A commit record is generated.
      A .gitkeep file is created at the bottom of the directory by default because Git does not allow a commit of an empty folder.
      On the Create Directory page, enter the catalog name and commit information, and click OK.
    • Create a submodule
    • Uploading a file
      Uploading a file on the CodeArts Repo console is to create a file and run the add, commit, and push commands. A commit record is generated.
      On the Upload File page, select the target file to be uploaded, enter the commit information, and click OK.
  4. Move the cursor to the file name and click to change the file name.
    Renaming a file on the CodeArts Repo console is to change a file name and run the add, commit, and push commands. A commit record is generated.
  5. You can click a file name to display the file content on the right of the page. You can modify the file content, trace file modification records, view historical records, and compare the file content.
Repository Name Tab Page: Viewing File Details of a Branch or Tag Version
By default, the repository name tab page displays file details of the master branch.
It contains the following fields:
  • File: name of a file or folder.
  • Commit message: message of the last commit to the file or folder (-m in the commit command). You can click the message to display the commit record.
  • Creator: creator of the last commit to the file or folder.
  • Update time: last update time of the file or folder.
Commit messages are required for the edit and delete operations. These operations are similar to -m in the git commit command and can be used to view associated work items.
History Tab: Viewing the Commit History of a Branch or Tag Version
The History tab page displays the commit history of a branch or tag version.
On this page, you can perform the following operations on the commit history:
  • Click a commit name to go to the commit details page.
  • Click to extend the following functions:
    • Create Branch.
    • Create Tag: You can create a tag for this commit. (What is a tag?)
    • Cherry-Pick: Use the commit as the latest commit to overwrite a branch. It is used to retrieve a version.
    • Revert: undoing this commit
    • Browse Code.
Managing Repository Files
You can click a file name to manage the file. The functions are as follows:
When you maximize the browser window, the functions in the drop-down menu shown in the preceding figure are displayed in tile mode.
  • File name: View the detailed content of the file.
    Table 1 Screen description
    Screen Function
    Function Description
    File Capacity
    Indicates the capacity of the file.
    Full Screen
    Full screen to view the file content
    Copy Code
    Copy the file content to the clipboard.
    Open Raw
    You can view the original data of the file.
    Edit
    Edit the file online.
    Download
    Download the file to the local PC.
    Remove
    Delete a file.
    File content
    The email content is displayed.
    Click to add a review comment. Max. 5000 review comments for a single MR.
  • Blame: View the change history of a file and trace operations.
    On this tab page, a modifier corresponds to their modified content. You can a record to view the commit details.
  • History: View the commit history of the file.
    • provides the following functions:
      • Create Branch.
      • Browse Code.
  • Comparison: compares the committed differences.
    The differences compared on the CodeArts Repo console are displayed in a better way than those on the Git Bash client. You can select different commit batches on the GUI for difference comparison.
    The comparison result shows the impact of merging from the left repository version to the right repository version on the files in the right repository. If you want to know the differences between the two file versions, you can adjust the left and right positions, compare them again, and learn all the differences based on the two results.
