Configuring a Repository-Level Merge Request Template
| Item | Description |
| Package constraint | This function is available only for CodeArts Repo professional and enterprise editions. |
| Permission constraint | You need to have the configuration permission. You can go to the homepage of the repository to be configured, click Settings in the navigation bar, choose Security Management > Permissions, and check whether you have the set permission of the repository. If you do not have the permission, see Configuring Repo-Level Permissions. |
Configuring a Merge Request Template for a Repository
- Go to the Test_Repo repository.
- Click Settings in the navigation bar and choose Template Management > MR Templates in the left navigation pane.
- Click Create MR Template and enter the configuration information by referring to Procedure.
After configuring the merge request template, view the configuration result by referring to Helpful Links.
