Viewing Commit History
CodeArts Repo allows you to view details about the commit history and related file changes. You can check the commit history on the Activities tab page of a repo or on the History tab page of the repository file list.
CodeArts Repo supports the following encoding rule types: UTF-8, UTF-16, GBK, and GB2312.
Viewing the Commit History on the Activities Page
Go to the homepage of the code repository to be viewed and click Activities to view all activities of the repository. To view the activities within a specified period, select a period on the right. To view the activities of a repo member, select the repo member from the drop-down list box on the right.
- All: If no time range or member is selected, the operation records of all members in the repo are displayed.
- Push: If no time range or member is selected, the push records of all members in the repository are displayed, for example, code push, branch creation, and branch deletion.
- Merge Request: If no time range or member is selected, the merge request records of all members in the repository are displayed. You can click the sequence number of a merge request to view details, such as creating, closing, re-opening, and merging of the MR.
- Review: displays all review comments of the repository. You can click the commit ID to view details where you can add or delete comments.
- Member: displays the management records of all members in the repository, for example, adding or removing members and editing member permissions.
You can view the commit history on the History tab page of the Files or Activities tab. Click a commit record to view the committer, commit number, parent node, number of comments, and code changes.
You can comment on a commit or reply to a comment.
You can click the icon in the following figure to switch the horizontal or vertical display of code change comparison. You can click Show All to view the full text of the files involved in the commit.
