Adding a Watermark to a Repository
You can add watermarks to the code display page of a code repository to protect your code and intellectual property rights.
Adding a Watermark to a Repository in a Project
Go to the homepage of the target project, and choose Settings > Security Management > Watermark. If this is enabled, the repositories will be displayed with the watermarks, that is, the account and time.
If you want all code repositories under the project to inherit this configuration, select Inherit from project.
Adding Watermarks to a Repository
Go to the homepage of the target repository and choose Settings > Security Management > Watermark Settings. If Inherit project settings is selected, all configurations will be the same as the project-level configurations and cannot be modified.
Click View details to go to the project-level configuration page and check whether the watermark function is enabled in the project-level configuration.
