Help Center/ CodeArts Repo/ User Guide/ Security Management/ Risky Operations on Repositories
Updated on 2025-09-23 GMT+08:00
CodeArts Repo allows you to change repository owners, delete repositories, and change repository names, but these operations are also risky. Exercise caution when performing these operations.
To configure risky operations, choose Settings > Security Management > Risky Operations. The following operations are supported:
  • Transfer Repository Ownership: Only the repo owner can perform this operation. You can transfer the current repository to another member in the repository.
  • Delete Repository: Only members who have the permission to delete repositories can perform this operation. Enter Delete to delete the repository. Once you delete the code repository, all its content will be permanently deleted. This operation cannot be undone. Please exercise caution.
  • Rename Repository: Only the repository owner can change the repository name. This will invalidate the original path for access and clone. Please exercise caution.
  • Transfer Repo: Only members who have the permission to delete repositories can perform this operation. This will invalidate the original path for access and clone. Please exercise caution.
    This function supports only a single repository.
