Feishu Group Chatbot
- Members in the repository can view this page. Only roles with the set permission in CodeArts Repo can configure this notification.
- The merge request event type applies only to the merge request mode.
Steps
CodeArts Repo supports subscribing to repository events to send notifications to Feishu groups.
You can click Use Project Notification Settings in the upper right corner to inherit the project-level configuration. The configuration cannot be modified. You can also perform the following steps to configure a specified repository.
- Go to the repository homepage to be configured. In the navigation pane on the left, choose Settings > General > Notifications.
- Enable Feishu Group Chatbot.
- Enter a URL, which is the notification URL for Feishu group.
- Set Type by referring to the following table.
Table 1 Parameters Parameter
Repo
Delete and Capacity warning. The default value for capacity warning is 90%, but other options are also available, such as 60% and 80%.
Merge Request
The following types of merge requests can be selected for notifications: opening, updating, merging, reviewing, and approving merge requests, creating review comments, and resolving review comments.
- @User IDs is optional, indicating the user ID of the addressed member. Multiple user IDs must be separated by semicolons (;).
- If the signature is enabled in the Feishu robot security settings, you need to set Secret Key.
- After setting the parameters, click OK to complete the configuration.
